hp is a quantity which is calculated from a measured quantity, torque the calculation is HP = (rpm x torque)/5250 here is a result based on a totally imaginary engine w/ 200 lb-ft of toque at every rpm from 3200 to 7200, the hp curve will constantly rise, now this never happens so any variation in torque will cause a consequent variation in hp
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-07-2012 at 02:39 PM.. |
Thanks Bill. I probably could have figured it out if I sat down and did the math, but thanks again. Big help.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
That graph was posted by mistake, it shows the hp curve of a modified engine from one data set but the torque curve from a theoretical engine, I corrected the mistake
