Bill Verburg's Avatar
Originally Posted by j911brick View Post
Maybe somebody can explain this?
I was at a dyno one day and a Honda had a flat torque curve. Pretty much straight all the way across. But the HP curve was as one would expect. Is this even possible with a mathematical model?
Also: I have always wondered: wouldn't changing tire diameter effect the dyno results? Why or why/not?
depends on whatt you mean by expect
hp is a quantity which is calculated from a measured quantity, torque
the calculation is
HP = (rpm x torque)/5250
here is a result based on a totally imaginary engine w/ 200 lb-ft of toque at every rpm from 3200 to 7200, the hp curve will constantly rise, now this never happens so any variation in torque will cause a consequent variation in hp
Bill Verburg
Old 03-07-2012, 02:34 PM
j911brick's Avatar
Thanks Bill. I probably could have figured it out if I sat down and did the math, but thanks again. Big help.
Originally Posted by Bill Verburg View Post
Sure it's possible
the calculation is
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 03-07-2012, 02:40 PM
That graph was posted by mistake, it shows the hp curve of a modified engine from one data set but the torque curve from a theoretical engine, I corrected the mistake
Bill Verburg
Old 03-07-2012, 02:43 PM
