Thinking about replacing mine, any suggestions?
Thanks! Rod
1989 911 Targa M491 1980 Triumph TR8 (sold) 2006 BMW M3 (Interlagos Blue) |
There are many choices but I settled with Magnecors. The claim is that they're of the highest quality and can withstand more extreme temperatures.....they've worked well for me. The OEM Beru's are completely "plug and play" and the others are a little more work to install. Cheers
I did the same - Magnecor (blue), I forget if the diameter was 8mm. You can check here too, as this question comes up once in a while.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Member 911 Anonymous
+1 Magnacors (red) but use the Beru dust guard they are made better for the heat. just use some di-electric grease and slip them on.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
76 911S Targa
I used Magnecors to replace my OEM Berus. Cleaned up a lot of running problems. They work and they are a reasonably priced product.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
I have the 10mm red magnecores, but wanted blue wires and decided to see if the blue wires I bought from paragon would work. They cost 65 bucks and I can't tell the difference between them and the magnecores. Granted, I have not sprayed water on them to see if they will arc, but since I wanted blue wires to match my car, they seeem to work great. Only time will tell and i'll keep the 10's just in case.
72 911 Although it is done at the moment, it will never be finished. |
I wonder why there's an $80 difference between the early 911 and the middle years' wires on that site?
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
+1 on the Magnecors. I purchased them from our host and have been running them for 2 years with good performance on the street and track.
Dave 1985 Factory Turbo-Look Coupe 2011 Cayman S 2012 Audi S4 |
Very happy with my Magnecors, also. Wish they weren't red though.
Dave Black 1985 911 Carrera M491 Last edited by djcdmv; 09-20-2011 at 05:36 AM.. |
In maintenance phase
I'm running magnacor wires. Love them.
I especially love the way the spark plug ends are made, it's a secure, sealed, well built unit. I expect them to last a long time. Haven't regretted the money spent. Good investment. -Dan
1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. |
How much work involved to get them to fit properly?
I really want somehting that is more plug and play ready, and in a perfect world Red in color to match the car. Rod
Jupiter 911
Rod, I went with the red Clewetts about three years now and never had a problem, great fit and great quality. I had to drill out the wire holders to keep the custom look and fit but that was simple, alot cheaper and better looking than Beru.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
SC Ray
Or, you could go with these:
Pelican Parts - Product Information: 10-8533-606-M47 Guess what - they fit perfectly and the people that designed and built your car think they are the best wires. ![]() You really can't go wrong either way - I just wanted and easy fit so I could do the work myself. Ray |
If you want plug and play, the Beru's are it. They come with all the brackets in place, (no drilling of plastic to accommodate larger wires, and no additional "spreaders" to keep everything orderly (like you have to do with the Magnecors, the Mags are way thicker than OEM) The Mags do come across as very robust and are available in red, doubt if the Beru's come in anything but basic black. Cheers
Cheers, Joe Last edited by stlrj; 09-20-2011 at 06:52 AM.. |
Yeah Joe, but can a guy own a 911 with a non orderly engine bay? Chaos I say, signs that civilization as we know it is heading down the tube ....LOL.
How about some pics!
Rod
