Taking it apart is easy
Jerome74911S's Avatar
Broken little stud - how to fix?
I'm redoing the interior. When removing the bracket where the safety belt retractor resides, the small stud on the top broke off.
Is this a removable stud? Is there a nut welded on the other side? Do I have to drill it out and tap the hole? Is there material to tap into?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-25-2012, 03:29 PM
Chief Head Scratcher
kerthunk's Avatar
Isn't that just a bolt coming in from the wheel well side? I had the same issue and I THINK that I just took that bolt out and replaced it with a new one.
John Morris
'79 911SC
Old 03-25-2012, 04:35 PM
KNS KNS is offline
It looks like you've added some sound proofing to the rear quarters (and other places I assume) - how did that work out?
Kurt
Old 03-25-2012, 04:56 PM
That could be, but I don't see how to reach the bolt if there's one in there. Plus, it is attached somehow. Welded in place?
Jerome
Old 03-25-2012, 06:07 PM
I did install soundproofing, but I am just getting to putting the car back together (and addressing this broken bit and other details). Therefore, I don't know how the mass loaded vinyl/closed cell foam will work - or if the rear upholstered panels will fit over it.
Jerome
Old 03-25-2012, 06:12 PM
Jerome,
I have a 74 Targa and at teh moment my interior is out including the seat belt bracket. On my car that is a stud not a bolt. I would grind the existing stud down and tack on a new one.
Old 03-25-2012, 07:53 PM
Thanks, that's the clue I needed - I didn't want to have to tear out the sound insulation to figure out what's back there.
Grinding on the agenda.
Jerome
Old 03-26-2012, 03:21 PM
