Exclamation porsche power problem
i have a 77 911s that has zero power up to 4000 rpm,
when i rev it in neutral it goes slower up to 4000 rpm than hesitates than takes off this happens but its subtle.
when its in first gear it has no punch up untill 4000 rpm
the compression seems fine with the lowest being 120psi and the most being 140
ive tried everything i can think of but i cant nail it
Old 03-30-2012, 05:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the fuel filter, it may be clogged
'85 Carrera Targa
PCA/POC
Old 03-30-2012, 07:47 PM
ROW '78 911 Targa
timmy2's Avatar
massive vacuum leak?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-30-2012, 08:22 PM
Dave Colangelo's Avatar
Dirty/work spark plugs, distro cap and rotor, bad plug wires, if there is a fuel pump relay check it, check fuel pressure as well.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 03-30-2012, 08:23 PM
Enthusiast
jrolstin's Avatar
Check WOT (wide open throttle) Make sure you are getting it, this was my culprit. A screw had backed out in the linkage and was only letting the butterfly open about 20 degrees! Adjusted it and BAM (Or as clarkson would say - Powerrrr)
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 03-30-2012, 11:22 PM
Targa Time's Avatar
If you ignition timing is off you may not be getting enough advance until the distributor spins with a higher RPM. Have you done a tune up recently where you may have moved the distributor?
81 Targa, Bamboo Beige, 3.2 SS
Old 03-31-2012, 05:06 AM
Tags
911 , power
