Obscure Cabriolet part question
I have an 88 Porsche 911 cabriolet with a power top. I recently purchased a windstop (or wind deflector). The way this installs is to replace the regular version of the side panel plugs (P/N 911.555.523.66) with a version of the plug that has a hole in the center. There are several different side panel plugs listed on Pelican:
OEM-911555523664XC
Genuine Porsche Part: SIDE PANEL PLUG
$4.25
OEM-911555523666WX
Genuine Porsche Part: CAP
$3.25
OEM-911555523666ZF
$3.25
OEM-9115555236670B
$4.25
OEM-911555523669JJ
My question - which, if any, of these plugs have a hole in the center that can be used with the windstop part number (000-043-202-10-OEM) ?
Does anyone using a factory windstop have those plugs, and iss the P/N visible on the inside? A brand new version of the windstop comes with the two replacement plugs, but I bought mine secondhand and the plugs didn't come with it. I could just drill a hole in my current plugs, but thought I would check first if the part is available.
thanks!!
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 05-03-2012, 07:39 PM
geoz's Avatar
I thought the windstop came with a plug that goes in the place of the original? Di you not get one? Where did you buyt the wind stop from?
cheers
hg
1988 911 Cabrio
Old 05-03-2012, 08:54 PM
Cattler's Avatar
Where'd you get the windstop?
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 05-04-2012, 05:04 AM
Like I said in my original post, I bought the windstop secondhand (although it appears to be brand new) but it did not come with the two plugs. That's why I am wondering if anyone can tell me the P/N of the two replacement plugs.
thanks
2016 Cayenne
Old 05-04-2012, 06:11 AM
Found it, with help from Pelican: OEM-00004320297
2016 Cayenne
Old 05-04-2012, 12:13 PM
French Import
zippy_gg's Avatar
Do you happen to have install instructions?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 05-04-2012, 03:22 PM
I didn't get instructions, but I found this :
Windstop for 1986 Cabriolet with mechanical top
I had trouble reading it, but I think its pretty simple to install, if you have the correct side panel plugs.
2016 Cayenne
Old 05-05-2012, 08:21 AM
