Obscure Cabriolet part question
I have an 88 Porsche 911 cabriolet with a power top. I recently purchased a windstop (or wind deflector). The way this installs is to replace the regular version of the side panel plugs (P/N 911.555.523.66) with a version of the plug that has a hole in the center. There are several different side panel plugs listed on Pelican:
OEM-911555523664XC Genuine Porsche Part: SIDE PANEL PLUG $4.25 OEM-911555523666WX Genuine Porsche Part: CAP $3.25 OEM-911555523666ZF Genuine Porsche Part: SIDE PANEL PLUG $3.25 OEM-9115555236670B Genuine Porsche Part: SIDE PANEL PLUG $4.25 OEM-911555523669JJ My question - which, if any, of these plugs have a hole in the center that can be used with the windstop part number (000-043-202-10-OEM) ? Does anyone using a factory windstop have those plugs, and iss the P/N visible on the inside? A brand new version of the windstop comes with the two replacement plugs, but I bought mine secondhand and the plugs didn't come with it. I could just drill a hole in my current plugs, but thought I would check first if the part is available. thanks!!
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
I thought the windstop came with a plug that goes in the place of the original? Di you not get one? Where did you buyt the wind stop from?
cheers hg 1988 911 Cabrio |
Where'd you get the windstop?
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
Like I said in my original post, I bought the windstop secondhand (although it appears to be brand new) but it did not come with the two plugs. That's why I am wondering if anyone can tell me the P/N of the two replacement plugs.
thanks
Found it, with help from Pelican: OEM-00004320297
French Import
Do you happen to have install instructions?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I didn't get instructions, but I found this :
Windstop for 1986 Cabriolet with mechanical top I had trouble reading it, but I think its pretty simple to install, if you have the correct side panel plugs.
