If you believe Chuck Mooreland of Elephant Racing, the rubber bushings should not slip, and all movement should be within the rubber itself. He claims his bushings fit tighter, and in addition, he glues them in place. Between the tight fit and the adhesive, his bushings should not slip. The other bushings may fit slightly more loosely, and when not glued, they may be more likely to slip. Slippage of the rubber bushings leads to wear and noise.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 11-30-2014, 12:02 PM
I am completely undecided now
1992 C2 964 (Nevada USA & France)
Old 11-30-2014, 12:13 PM
I replaced mine with the Elephant stock bushings, and used the instant glue they included. I apparently didn't do it correctly and it didn't adhere even through the installation - while reindexing the bars, the glue let go. I did it again with better cleaning and prep - this held for a few miles, then I started hearing the squeak/crunch again over large bumps (like speed bumps).
I took it apart while doing a corner balance, and really prepped it carefully, used a ton of instant glue, and it held for a few months. Now, however, I'm hearing the noise over large bumps again, especially in cold weather.
Originally Posted by 88911coupe View Post
++1 on what Dave says. I went to extremes to find some epoxy that worked on rubber to metal and finally found one. Went through the whole process and I can just hear a rubbery squeak over large speed bumps. I suppose it's possible the glue actually has held and that I'm hearing the OD rubbing/moving inside the hole/recess but I strongly suspect the glue has let loose. Good news is they are totally silent on anything but a major speed bump so I know they aren't moving, except in extreme situations.
What epoxy did you use?
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 11-30-2014, 01:41 PM
gjs
glennspiegler's Avatar
The glue was supposed to be JB Weld, which I did. Must continue to hit grease fittings every oil change with a thin grease. Occ sqeak when cold on a speed bumpl
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff
2015 Cayman S
1948 Willy's Overland Jeepster
2013 Chev Sub
2004 Nisson Xterra
Old 11-30-2014, 02:32 PM
jittsl's Avatar
I installed bushings without glue and they squeaked like a manic mouse. Replaced them very quickly with Elephant poly bronze bushes - love them.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 11-30-2014, 04:16 PM
It was 3M Scotch Weld Epoxy DP-100 Plus. I could only find it at McMaster Carr. Supposed to work on steel and rubber. I don't think it held when temps really dropped and the Neatrix bushings stiffened up.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-30-2014, 07:53 PM
