LinkBack | Thread Tools | Rate Thread |
If you believe Chuck Mooreland of Elephant Racing, the rubber bushings should not slip, and all movement should be within the rubber itself. He claims his bushings fit tighter, and in addition, he glues them in place. Between the tight fit and the adhesive, his bushings should not slip. The other bushings may fit slightly more loosely, and when not glued, they may be more likely to slip. Slippage of the rubber bushings leads to wear and noise.
Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
I am completely undecided now
1992 C2 964 (Nevada USA & France)
I replaced mine with the Elephant stock bushings, and used the instant glue they included. I apparently didn't do it correctly and it didn't adhere even through the installation - while reindexing the bars, the glue let go. I did it again with better cleaning and prep - this held for a few miles, then I started hearing the squeak/crunch again over large bumps (like speed bumps).
I took it apart while doing a corner balance, and really prepped it carefully, used a ton of instant glue, and it held for a few months. Now, however, I'm hearing the noise over large bumps again, especially in cold weather. Quote:
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes. 1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights. |
gjs
The glue was supposed to be JB Weld, which I did. Must continue to hit grease fittings every oil change with a thin grease. Occ sqeak when cold on a speed bumpl
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra |
I installed bushings without glue and they squeaked like a manic mouse. Replaced them very quickly with Elephant poly bronze bushes - love them.
Laurence 1998 Specbox racer / 1998 Boxster / 1984 RSR tribute 1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa 1963 356B T6 Coupe / 1962 356B T6 Cabriolet Current projects - 1955 356 pre-a Speedster / 1964 356C |
It was 3M Scotch Weld Epoxy DP-100 Plus. I could only find it at McMaster Carr. Supposed to work on steel and rubber. I don't think it held when temps really dropped and the Neatrix bushings stiffened up.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
