vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
First Timer - New Clutch Replacement
Wanted to check with the board before I purchased the parts to replace my clutch in my '83 SC. It is due and since I pulled the motor I thought now was a good time. What all parts should I buy? I do not want to replace more than I have to since I spent way too much on the SSI's and muffler but do not want to have to pull the motor again anytime soon. Getting conflicting stories and wanted to hear from the forum.
Any other tips are welcome.
Thanks in advance!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-04-2012, 02:35 PM
porsher
aston@ultrasw.c's Avatar
Well, strictly speaking you don't have to replace anything.
If you buy half, the other half will fail and you will be pulling the motor again.
If you buy the lot it will cost more...
Pick your poison.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-04-2012, 03:54 PM
Peter Zimmermann's Avatar
Disc, pressure plate and throw out bearing. Pilot shaft bearing, crank seal at the flywheel, main shaft seal. TOB release fork. Flywheel and throw out bearing guide tube are the big questions; must see them, then decide.
If they haven't been replaced in recent memory: Oil pressure warning switch, thermostat o-ring, throttle lever bushings, injector sleeves/o-rings, crank breather hoses.
Then to top it all off, a new, o.e., clutch cable, clevis, clevis pin, and clevis pin bushing. And new seals for the release fork shaft.
Keep the Shiny Side UP!
Pete Z.
Old 05-04-2012, 04:47 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by Peter Zimmermann View Post
TOB release fork.
Listen to Peter on all of his recommendations.
I had not thought of the fork, but Mayo, who rebuilt my trans strongly advised that I replace this for insurance. So that is two professional sources recommending this. Do it.
Peter, you did not recommend replacing the flywheel bolts. Is that a requirement?
Edit - I would have the flywheel ground even if it looks good.
Old 05-04-2012, 09:17 PM
check clevis end on clutch cable at pedal assy. and shaft it connects to for wear.
Old 05-04-2012, 11:48 PM
vesnyder's Avatar
Good stuff guys. Thanks!
Vance
Old 05-06-2012, 05:22 AM
Mo money = mo parts
This is what I would do too, it's a little extra money, but you will end up with a nice new, sweet-feeling clutch that will perform well for many miles.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-06-2012, 06:14 AM
Immature Member
dentist90's Avatar
+1 on the release fork. I reused mine when I replaced the clutch components 35,000km ago. It cracked this year and I am back in there again.
As far as the flywheel bolts, I have reused mine twice now. I have heard them referred to as stretch bolts, but they are only torqued to 67 ft-lbs and they are stout little fellas. I thought stretch bolts were torqued to a specific value and then turned an additional 1/4 turn to deform (stetch) them.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-06-2012, 01:12 PM
Mo money = mo parts
Flywheel bolts are $25. There are lots of opportunities to minimize cost, but a 10lb steel plate spinning at 5,000 rpm isn't it. The standard rule that pretty much everyone accepts is flywheel bolts are replace 100% of the time.
Greg
Old 05-06-2012, 05:48 PM
On a 6 bolt flywheel, I'd invest in the new bolts. The 9 bolt flywheel (the poster has this) stays on much better. I'd feel very safe reusing these bolts with a visual inspection.
-Andy
Old 05-06-2012, 08:56 PM
Your second engine drop will be much easier than the first.
I know what I'd do (pilot bearing, engine seal, clean TO shaft, new flywheel bolts, pres switch and thermostat o-ring).
What makes you think the clutch disc is bad?
Old 05-07-2012, 12:21 AM
