Just rebuilt all my clalipers, how to bleed
I just rebuilt all my calipers with Pelican rebuild kits. I pinched the overflow tube, and capped the brake lines asap when removing them. Naturally, there was a siginificant amount of brake fluid in the calipers themselves, when I disassembled them to clean and put the new seals in. I put them all back on the car and pushed a pint of brake fluid though the system with my pressure bleeder, hitting the calipers with a rubber mallet, but there must be tons of air in the system as the pedal is horrible.
Any tricks to getting all the air out after a rebuild? I was going to get another pint of fluid and repeat the process, but not sure if that will do the trick. Thanks, Doug
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
One of the tricks I was taught was to "exercise" each caliper using some totally worn out pads and an expander tool. With the pedal pump the brakes (with the "padless" pads installed on one) until the pistons are fully extended, them push them all the way back using the expander, repeat this process 5 times per caliper in the same order you bleed and bleed after each 5 rep "exercise".. when done go around and bleed one last time.
Gary R. |
Member 911 Anonymous
As simple as it may sound go to your FLAPS and get the one man bleed bottle for under $10.00 and about 6' of clear tube from HD.
Jack the rear as high as you dare to allow any remaining trapped air in the line to creep up and back to the rear calipers then work the fronts. Place catch bottle higher than the calipers and the car itself, open the valve and start pumping until more air is out of the system. No need to open and close the valve while doing this the fluid in the line will keep air from coming back to the calipers. Also as not to damage the MC place a piece of 2X4 block behind the pedal, you do not want to depress all the way to the floor but press hard and quickly. WATCH THE AIR GO UP THE TUBE ![]() I had to do this about 3-4 times to get all the remaining air out of my system, but I used 4 different systems, 2 man, Vacuum, Reverse Bleed and finally the one man bottle trick. This method also use the least amount of new fluid. PM me if you have any detailed questions. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
+1, positioning the new pads as close to the rotors will help as well.
Those are both good ideas. My calipers, themselves, were full of air after the rebuild. However, the lines should only have a foot or so of air in them, as I did cap them quickly, and never allowed the brake resevoir (sp?) to empty.
Got an assistant? This is a 15 min job with two people, just did two new front calipers a few weeks ago. Assistant pumps them, you open the bleeders, rinse and repeat, same as any other car I've done.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Tim
What Scott said. Tried multiple methods (including powerbleeders) after rebuilding my calipers and the best way by far was the 2 person procedure.
Local Mad Scientist
+1 with Scott.
If you have trouble finding an assistant try louring him with beer and pizza. Worked on my brother.
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
I think I will try the 2 person. Seems like the high pressure / release really pushes the air through the system, unlike the power bleeder, which pushes at a low pressure. Will report back ...
Fleabit peanut monkey
All of the above. Don't be afraid to drive it a few days and do it again. That gives me the best results but I am not as thorough as DRACO and have not tried all of his ideas.
However, when I finally nailed it, the pedal was unbelievably firm at the top. Very little travel with a stock set up. |
Hanging on for a solution as I'm planning the same rebuild.
THANKS!
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
You didn't by chance put the calipers on the wrong side?
Bleeders need to be at the top of the calipers.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
disband
after a rebuild the calipers even when bled will be spoongy a bit. need to heat em up a bit then bleed again. many other threads on that issue.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I do suspect I will need to put some miles on them, then bleed them again. In retrospect, I suppose I could have filled the calipers up with fluid before installing them. Not sure how much difference that would make. I did make sure the bleeders are on top.
I excercise the new seals before I put the calipers back on the car. Using the same method with wood and C clamps to get them out. A half dozen times on each side seems to work good.
Bob D 1982 RoW Silver 911SC - PCA E #339 1997 993 Turquoise Blue Carrera S |
I rebuilt my master cylinder and replaced my rubber brake lines and did the gravity bleed method. It worked great. Go in this order RR, LR, FR, LF. Put clear tubing on the caliper bleed valve in the order just mentioned and do them one at a time. The clear tubing needs to stretch vertical with the end above the level of the brake reservoir. Keep filling the reservoir as the level drops.
Craig '69 911T |
