Burn the fire.
Brando's Avatar
Carrera Compression Testing Numbers
As some of you may have seen, my 1987 Carrera 3.2 is for sale. Today I did the compression test and the numbers are as follows:
Cylinder 1: 176 psi
Cylinder 2: 175 psi
Cylinder 3: 176 psi
Cylinder 4: 174 psi
Cylinder 5: 172 psi
Cylinder 6: 175 psi
For a stock USA engine with 220k, these are pretty good, yes? I did the test with the engine warm, WOT and no other spark plugs removed.
I want to do a leak-down test, but I do not have any contacts local with an air compressor and the tool.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-05-2012, 10:12 PM
RETIRED
Joe Bob's Avatar
I have a portable compressor....
2012 ML350 3.0 Turbo Diesel
Old 05-05-2012, 10:14 PM
geshaghi's Avatar
Those numbers seems excellent to me, and a remarkable improvement over what you initially posted. Curious what accounted for the difference between the first test and the second test?
George E.
www.autoinno.com
www.AIRMotorSports.com
Old 05-05-2012, 11:03 PM
Burn the fire.
Brando's Avatar
Smile
I take that back, I know one local. Joe, do you have the leakdwon tester as well?
The initial test I left the throttle closed. The second time I had an assistant to keep the driver's seat warm, turn the key to crank the engine and also hold the throttle down.
Old 05-06-2012, 09:02 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeah JB you got the leak down tester? I may need a hand toooooooooooooooo.
Please correct me if I wrong but don't we want to disconnect the fuel (in my case disconnect the dme relay) to do compression test so fuel is not added to the compression readings??? We want it to crank not ignite, right?
'85 Carrera Targa
PCA/POC
Old 05-06-2012, 09:15 AM
Burn the fire.
Brando's Avatar
Correct - pull the DME relay! Stops both spark & fuel.
Old 05-06-2012, 09:19 AM
DRACO A5OG's Avatar
Hewh! I thought I did it wrong all this time, Thanks Brother!
BTW, your numbers look great, within 10% of each other is ideal from what was told to me by the experts.
'85 Carrera Targa
PCA/POC
Old 05-06-2012, 09:23 AM
RETIRED
Joe Bob's Avatar
I have a compression checking device and portable Makita compressor.....no leak down equipment.
I don't think they are real expensive. I'm sure HF has a cheap China made one. Summit has them for 70 bucks and up.....Autozone as well. Split it with Brando, sell it when done.
I've never had need of one, so not part of my collection.
Old 05-06-2012, 09:25 AM
DRACO A5OG's Avatar
, like my LM2 sitting on the shelf
'85 Carrera Targa
PCA/POC
Old 05-06-2012, 09:33 AM
RETIRED
Joe Bob's Avatar
The guy with the most tools.....has the most tools....
Old 05-06-2012, 09:34 AM
al lkosmal's Avatar
I would recommend buying you leak down tester from Aircraft Spruce. Much better quality than the HF version....for just a few additional $.
http://www.aircraftspruce.com/catalog/topages/cylpresse2a.php
regards,
al
PS: I have both...............
RGruppe #669
http://www.x-faktory.com/
Old 05-06-2012, 09:39 AM
DRACO A5OG's Avatar
Want to visit us SoCali? Beer on JB
'85 Carrera Targa
PCA/POC
Old 05-06-2012, 09:43 AM
RETIRED
Joe Bob's Avatar
Pelican Parts.com - Cylinder Leak-Down Tester
Looks like Our Host has a kit as well.
Jim, thanks for volunteering me for beer beeyotch....
Old 05-06-2012, 09:49 AM
