Racer
Well, either way, Loren has done such a good job of "marketing" here that I would never buy anything from him or use his services. I suspect I am not the only one that feels that way.
Scott |
why dont you use the "quote" feature at the bottom of the posts like everyone else? it makes it sooo much easier to read vs you copying and pasting someone Else's post. it looks like what you paste is part of what you are saying.
Almost Banned Once
This thread reminds me of the threads on audio sites arguing about which turntable is the best.
![]() Just get out a drive your 911s...
- Peter |
...and now everyone has lower fidelity ipods and high resolution big screens that they watch low resolution downloaded movies on
![]() Quicksilver, thanks for adding the missing technical details. I do think we are making the same point in case it was unclear the point I was making. Loren, there are a significant number of owners who would not have anything but original equipment parts. I also assume that a porsche ignition is pretty good particularly compared to other car manufacturers of the time, so for many there is merit in keeping what the factory provided. I think that is your target market. I just come here to learn things.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Racer
"1. a more direct power connection to the battery instead of old wiring running through a switch."
This is a requirement for the MSD since it has 2X the peak current needs of the Bosch unit. The low current requirement of the Bosch unit versus the MSD's doesn't present a problem for the ignition switch. "2. a direct ground from the coil back to the MSD unit." Most 911 Bosch factory installations have 2 grounds. "3. the components are not old and been exposed to heat for 30 years." Not a real issue for many, especially since the Bosch unit doesn't use electrolytic capacitors, like the MSD, which have high failure rates with high temps found in the engine compartment. So if one is concerned about heat problems, the MSD is a poor choice. "4. more components does not make it worse. the permatune has far less than both of these, does that make it the best." It's a FACT that as the number of components increase in ANY system, the failure rate also increases. As can be seen by the image of the inside of the MSD unit, it has over 5X as many components as the Bosch. It uses more power semiconductors than does the 911 3.2 DME ECM which also controls the fuel. The Perma-Tune is an inappropriate example as it has a design problem unrelated to its component count. "5. porsche saw the need to put out 350kv, what proof do you have that 450kv is not better? the higher voltage has a better chance of firing a fouled plug, no?" At idle the Bosch unit puts out about 400KV and at high RPMs the voltage is about 350KV. It's rise time (the time to go from 0 volts to max volts) that determines the spark's ability to fire a fouled plug. In both the MSD and the Bosch, the rise time is way under a microsecond. That was the plus in using the CDI system in the late 60's versus the early transistorized inductive discharge ignition. The increased MSD voltage has insignificant advantage over the Bosch unit.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 05-10-2012 at 09:33 AM.. |
Obviously a factory design problem, which MSD overcame, inherent in the OEM CDI. On the other hand a few electrolytic capacitors at the front end of the OEM CDI Would also undoubtedly improve its reliability. Last edited by wwest; 05-10-2012 at 10:36 AM.. |
you claim a narrower pulse. have you proved that a narrow pulse makes a difference? higher voltage. MSD supplies new wires to handle the 450v. have you proved the cap and wires cant handle at the most, 100kv more voltage? ill give you the rotor. where is the proof that the extra 100v will NEVER make a difference on someones car? the MSD is less reliable. where are the numbers? direct power for the MSD is a positive. if not, prove it. direct ground from the coil to the MSD is a positve. if not prove it. you have been challenged with a way to prove the multi spark works or does not, are you going to follow through with it?
i have seen on more than one post where someone had 12v at a light socket but the bulb would not light. high resistance somewhere reduced the current enough so the bulb would not light, but the meter reads the 12v. this could happen to the CD. bad switch, bad connector. the MDS has one wire that goes to the battery.
this is why i always tell people to use a test light. the test light would have found the high resistance and not confused somene with a 12v reading.
AutoBahned
Come back and comment on how that MSD is doing 30 years from now.... My guess is it'll be in a landfill in less than 10 years.
SOLD: '87 Carrera |
To clarify, there is a corrilation between spark CURRENT and engine power output in a twin plug application. Is that better?
Tell it like it is or don't tell it at all. |
"We have dyno tested this on a very good 2.0 HSR race engine using single MSD box driving 2 Blaster coils and it ran and seemed OK until we read the power #'s compared to 2 boxes,2 coils. This engine made north of 230 HP on the 2 box setup and lost almost 15 HP on the single box split signal to 2 coils. we have repeated this test on various sizes and levels of build, non made equal power with the single box.
Mike Bruns JBRacing.com" __________________
Tell it like it is or don't tell it at all. Last edited by lindy 911; 05-10-2012 at 01:51 PM.. |
Almost Banned Once
- Peter |
Almost Banned Once
Continuum Caliburn (Australian made)
- Peter |
Almost Banned Once
- Peter |
AutoBahned
Does the Continuum Cali-burn have multiple sparks?
With the name "Continuum" you'd think it had a continuous spark... And if it is made in Australia, why do they call it "Cali" burn? |
Racer
"Caliburn" is another name for King Arthur's sword "Excaliber".
Scott |
