Pop-off Valve Epoxy????? Help!
OK The hole is drilled the valve fits fine but what type of epoxy should I use?? The kit did not come with any and I can't find any info on what to use. What have you guys used? Help! My Porsche awaits!!
Thanks in advance!!!
WHITE 1983
911SC COUPE!
Old 05-07-2002, 10:25 PM
As virtually all plastic is oil based my recommendation is for a slow set epoxy. (the 24 hour kind). I base this on recommendations from Radio Contol airplane model building. The consensus there is that the slower setting epoxy has a better bite than the 5 or 15 minute type when used on plastics or GRP (glass reinforced plastic).
Howie
79SC
Old 05-07-2002, 10:36 PM
Chuck Moreland's Avatar
I used JB Weld. It has a higher temperature range than regular epoxy, although I don't recall what they spec.
Has worked well.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-07-2002, 11:08 PM
