Pop-off Valve Epoxy????? Help!
OK The hole is drilled the valve fits fine but what type of epoxy should I use?? The kit did not come with any and I can't find any info on what to use. What have you guys used? Help! My Porsche awaits!!
Thanks in advance!!! ![]()
WHITE 1983 911SC COUPE! |
As virtually all plastic is oil based my recommendation is for a slow set epoxy. (the 24 hour kind). I base this on recommendations from Radio Contol airplane model building. The consensus there is that the slower setting epoxy has a better bite than the 5 or 15 minute type when used on plastics or GRP (glass reinforced plastic).
Howie 79SC |
Author of "101 Projects"
Any good two-part epoxy available from Home Depot should suffice...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I used JB Weld. It has a higher temperature range than regular epoxy, although I don't recall what they spec.
Has worked well.
Chuck Moreland - elephantracing.com - vonnen.com |
Thread Tools | |
Rate This Thread | |
