shahram's Avatar
which header size?
I am finalizing my Carb conversion project and need to figure out which header size (inside diameter of primery tub) to take for my 3.6 engine.
It is a stock 993 3.6 engine but with PMO 50 carbs and direct ignition.
I don't need heat and was thinking about Dansk, Bursh or something like that but wanted to consult you guys before I order the headers and find out they are to big or to small.
Old 05-20-2012, 10:17 PM
Senior Advisor
James Brown's Avatar
check out rarlyl8 headers, just tell them what you have and what you want and the will make a great set of headers.
08 Cayenne Turbo
Old 05-20-2012, 11:32 PM
Bill Verburg's Avatar
1.75" OD ~30" primaries, you can get buy w/ 1.625" for street and occasional track use, 1.5"OD for street use only these will kill top end
rotating collector is best, size is unimportant if muffled
Bill Verburg
Old 05-21-2012, 06:25 AM
shahram's Avatar
Great, thanks Bill & James. I have a set of 1.625 laying around and will go with that for now. The car is for street use and maybe 1-2 DEs in the year.
Old 05-21-2012, 07:53 AM
