which header size?
I am finalizing my Carb conversion project and need to figure out which header size (inside diameter of primery tub) to take for my 3.6 engine.
It is a stock 993 3.6 engine but with PMO 50 carbs and direct ignition. I don't need heat and was thinking about Dansk, Bursh or something like that but wanted to consult you guys before I order the headers and find out they are to big or to small. |
Senior Advisor
check out rarlyl8 headers, just tell them what you have and what you want and the will make a great set of headers.
08 Cayenne Turbo |
rotating collector is best, size is unimportant if muffled
Great, thanks Bill & James. I have a set of 1.625 laying around and will go with that for now. The car is for street use and maybe 1-2 DEs in the year.
