Question: If Upgrading to A Calipers from M, do I need to add a Brake Booster
I have a '74 with M calipers and no Brake Booster.
If I were to upgrade to A calipers, would I also need to add a Brake Booster or could I go with my standard 19mm non-bosted MC?
I'm asking because I already purchased a vacuum booster and that thing is pretty heavy. I'd leave it out if I knew that the A's will do ok without it.
Just doing my research at this point....I still need 3.5" strut housings - this may be a "next year' project.
Thanks..............Vern
Old 05-30-2012, 10:14 AM
Bill Verburg's Avatar
The stock 19mm m/c will be fine
Just a FYI, the booster is not a simple bolt in, you will need to modify the trunk floor and linkage
Bill Verburg
Old 05-30-2012, 10:27 AM
I've been saving photos of every trunk I could find and I've got it mostly figured out. I think the hardest part would be running the vacuum from the back to the front. I bought the booster with all the linkage and pedals. Cutting a hole in the trunk floor is not something I will do without absolute clarification and measurements - I'm glad to hear I may not need to do this afterall.
I think my 1st pass will be to just try the calipers with no booster.
Old 05-30-2012, 10:44 AM
