LinkBack | Thread Tools | Rate Thread |
Question: If Upgrading to A Calipers from M, do I need to add a Brake Booster
I have a '74 with M calipers and no Brake Booster.
If I were to upgrade to A calipers, would I also need to add a Brake Booster or could I go with my standard 19mm non-bosted MC? I'm asking because I already purchased a vacuum booster and that thing is pretty heavy. I'd leave it out if I knew that the A's will do ok without it. Just doing my research at this point....I still need 3.5" strut housings - this may be a "next year' project. Thanks..............Vern |
Just a FYI, the booster is not a simple bolt in, you will need to modify the trunk floor and linkage
I think my 1st pass will be to just try the calipers with no booster. Last edited by Tidybuoy; 05-30-2012 at 11:47 AM.. |
