vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Need to Extend O2 Sensor Wire
I need to splice an extension wire into my O2 sensor since I installed SSI's on my SC. One of teh guys called for Mil-Spec wire but sourcing seems to be a challenge. Anybod have wire that might fit the bill? How about a heat wrap that I can use to cover the 6 inches exposed by the heat exchangers?
Any help or sources would be appreciated.
Thanks!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-11-2012, 12:34 PM
Prowire USA
Old 06-11-2012, 12:50 PM
Flat Six
Flat Six's Avatar
Interesting perspective crimp v. solder of O2 senor leads here:
O2 sensor extension SSI install
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-11-2012, 01:16 PM
vesnyder's Avatar
Thanks! ProWire set me up!
Vance
Old 06-11-2012, 02:25 PM
Diss Member
Quicksilver's Avatar
The link touches on, then ignores the issue with O2 sensor wires. The sensor 'breathes' thru the core of the wire so the wire must not be soldered. Not sure if you must have a specific type of wire to get the airflow that is needed but the generic Bosch replacement O2 sensor comes with quite a long lead on it which solved my length issues when I added headers..
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-11-2012, 02:31 PM
vesnyder's Avatar
I went and priced the Bosch O2 sensor and the lead wire it came with was about 2 inches long. Not sure which version comes with the long lead. The version of the Bosch O2 sensor I priced came with a crimped connector.
Vance
Old 06-11-2012, 05:09 PM
