When Taking Out the Engine and Trans Together..
Do I need to remove all the clutch levers and springs? Or can I just remove the cable and leave all the rest alone? I don't want any snap surprises though.. If I don't touch it while out, will it be fine?
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Simpler to just remove all the bit so you don't have to worry about them.
2002 Boxster Speed Yellow |
Fleabit peanut monkey
It will be fine.
if you are not separating the engine and trans, you can leave that stuff alone.
