The Dude abides...
bigel's Avatar
Question Help Identifying Please...
So I've been having a nice time attempting to rid my 87 Targa of a few rather large mouse residences...yeah, I'm hatin' it. Anyway, one of the nests was inside of the boot area within the passenger side fender wall. The nest was just inside a rather large pass-through hole that has two threaded studs on either side of the hole.
I've been trying to identify what might have, at one time, filled the void and been fastened down using the studs that protrude from this area in the interior fender wall.
Well guys, any ideas?
'03 Carrera 4S
Old 06-18-2012, 10:06 PM
Rescuer of old cars
Arne2's Avatar
There are no studs around that hole on my '84 coupe - just an empty hole with a few wires feeding through it. Mine does have a protector on part of the hole to keep the wires from chafing.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 06-18-2012, 10:32 PM
The Dude abides...
bigel's Avatar
Bump...
'03 Carrera 4S
Old 06-19-2012, 07:41 AM
schumicat's Avatar
on the driver side that hole is used for the fuel filler hose. I suspect the tooling just had the dies set up symmetrically, e.g., for right hand drive cars. The studs were probably by added by a previous owner so a block off plate could be used to seal the hole. my sc doesn't have studs.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-19-2012, 08:37 AM
Dublinoh's Avatar
On my 87 Carrera coupe the studs are also present, looks exactly like OP's picture.
Old 06-19-2012, 09:05 AM
The Dude abides...
bigel's Avatar
...very interesting, the mystery continues...
'03 Carrera 4S
Old 06-19-2012, 09:12 AM
The Dude abides...
bigel's Avatar
+Bump
'03 Carrera 4S
Old 06-19-2012, 07:44 PM
This is just a wild guess but could the studs have been added by the factory during the period that the "slant nose" was being built. Possibly to anchor the wiring harness or equipment related to the pop up headlights. And if so, the factory could have added the studs to all cars for convenience.
Old 06-19-2012, 08:44 PM
Hydrocket's Avatar
This is the correct answer. I work in the automotive industry and have worked with molds and dies. This is what they do for cars in multiple markets with LH or RH drives. And even in single markets, rather than design a different part, they often just mirror the design over for the opposite side. Saves on design and manufacturing time.
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 06-20-2012, 12:37 AM
The Dude abides...
bigel's Avatar
The only thing is...there's no studs on the driver's side where the fill tube passes into the luggage area.
hmmmmmmmm
Come on Joe Bob! Where's your $0.02 been?
'03 Carrera 4S
Old 06-20-2012, 03:24 AM
Dublinoh's Avatar
hmmmmmmmm
Ok, a guess...maybe the studs were part of the manufacturing process to align in a jig or something....and they were removed when the fuel filler was on that side. Shot in the dark, and I know I'm no Joe Bob
Old 06-20-2012, 05:34 AM
The Dude abides...
bigel's Avatar
Anyone else????
'03 Carrera 4S
Old 06-21-2012, 03:21 AM
donagain1's Avatar
My Cab's an '85, and that is the exact area which had holes drilled through, and an alarm siren mounted. I'm talking a real siren... motor, turbine, sounded like an ambulance from a '50s TV show. It had a Bosch relay and a "flasher" unit to cycle it on/off/on/etc to make it "whoop-whoop" instead of wail, if you get the subtle difference. It's possible that the hole is a nockout for a fender-well mounted loudspeaker for a modern style electronic alarm That'd be MY guess.
Old 06-24-2012, 02:45 PM
The Dude abides...
bigel's Avatar
Originally Posted by donagain1 View Post
?..It's possible that the hole is a nockout for a fender-well mounted loudspeaker for a modern style electronic alarm That'd be MY guess.
Nice thought, Don...maybe I'll install a loudspeaker for tailgating party music. Or better yet, a P.A. To scream at all of the JO's that cut me off during my joy-rides!
'03 Carrera 4S
Old 06-26-2012, 06:12 PM
The studs are for mounting the vacuum reservoir for the vertcal headlight aim control.
I believe '87 was the first year for this option/feature, of course this was not available in North America so many have never seen one.
Old 09-17-2012, 09:17 PM
I am currently working on an '87 930 with the "M605, Headlamp Vertical Aim Control" option.
Here is a pic of the vacuum reservoir on the studs.
Old 02-01-2014, 02:49 PM
ROW '78 911 Targa
timmy2's Avatar
Cool... Vertical headlight aim control.... I want that for the ricers with the poorly aimed super bright lights, Just hit a button and make them feel my wrath......
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-01-2014, 11:13 PM
