ghamilton's Avatar
A quote from my shop who do a lot of high end cars and customs windows:
"We use a Sika product called Mach-60 to seal rubber to body and rubber to glass. these are used mainly to prevent water from entering car."
https://can.sika.com/en/solutions-and-products/new-products/sikatack-mach60-autoglass-replacement-adhesive.html
NFI
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 02-19-2018, 12:08 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That Sika Mach-60 is basically rubber urethane adhesive. It's for the later style windshields (993-up) that do not use a preformed seal and are glued into the body, then decorative trim applied afterword. The stuff turns to pure rubber when cured. One of 3M's version like the Mach-6- stuff is called Windo-Weld.
We want to fill the void around the seal with a bedding and glazing compound. It's a non-hardening tacky goop that fills the void. The urethane stuff is not a problem, it's just unnecessary because it makes for extra work the next time the glass is removed and replaced
Kevin L
'86 Carrera "Larry"
Old 02-19-2018, 12:22 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Of course my German neighbor had something to say: "You must do it like the Porsche factory says."
Which is?
So the argument would be that new materials offer a better solution to what they had then.
In the mean time, I am back to cleaning old window cement from the windshield and Targa window channel....
Maybe with benzine!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 04-15-2018, 11:35 AM
wayner's Avatar
The current argument that people use is an assertion that the factory didn’t use ANY
I’ve asserted that while you can debate the modern glues, you should use a glazing compound at least
You document FINALLY supports that
Thank you thank you thank you
SOLD - 914 wide body hot rod
Old 04-16-2018, 02:54 PM
wayner's Avatar
3m Auto Bedding and glazing compound
Old 04-16-2018, 02:57 PM
