Somewhat obsessed......
CIS sensor plate
Hello all! I'm a relatively new SC owner and frequent lurker! It's now my turn to pose a question to the brain trust. I recently suffered the famed exploding airbox (I know I know) any way this was the final straw as I also have a broken headstud and the (still unexploded) clutch. So I have the parts (mit der pop-off valve) and while preparing to remove the engine I noticed that the sensor plate doesn't seem to have any spring tension. I previously thought that it did in both directions. Can a back fire ruin this as well? I may be just paranoid but pushing it up does'nt seem do operate anything. Broken frequency valve or plunger? I sure hope it's not fuel distributer time as well. Any help would be greatly appreciated!
Chris
Old 07-03-2012, 10:08 AM
Local Mad Scientist
Andy911sc's Avatar
I didn't have any resistance when pushing up on my sensor plate. I did further investigation and found that my plunger was seized up into my fuel distributor. Which explained why I was running super rich (the fuel distributor was running full open) I sent mine off to Brian Bodart with RarlyL8 to be rebuilt.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 07-03-2012, 10:21 AM
With no fuel in the FD it just flops around. run the pump and see if there is slight resistance.
A VW guy starting to work on Porsches
Old 07-03-2012, 11:51 AM
cis sensor plate
Thanks!!I bet it is the lack of fuel pressure. I'll find out soon enough.
Old 07-04-2012, 05:26 AM
