What do you do when 93 Octane is not Available?
Kinda getting my learn on about ROW euro cars, primarily 84-89 3.2 cars. One thing I have seen several times is folks saying their car is set up to take 93 octane. In many states this is no longer available. So what do you do??
Is 91 a major no-no in these cars? Do octane boosters work? Some say no.....some say they use them Are there economical mods that can be done to limit damages from using 91? Do the mods limit the HP/performance of the car? Thx |
Chain fence eating turbo
Octane boosters are snake oil.
Maybe get a computer chip from Steve Wong who makes a 91 octane friendly fueling map and enjoy instead of worry. |
Reiver
91 is fine. The European rating is diff than the US. Check it out and you'll find that compatbility is easier than you think.
My Euro seems to run fine on 91, but I run 94 locally, however on tours it isn't always available...so 91 it is.
91 should be fine. We have race cars with Euro pistons that run 91 octane.
-Andy
72 Carrera RS replica, Spec 911 racer |
Maybe this helps: From my original '79 manual:
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Which states!??!?!?!?!????!?
![]() EDIT: Been corrected by Quicksilver and JavaDog below. Thanks guys! Take care! Last edited by FrenchToast; 07-06-2012 at 03:10 PM.. |
California and Maine for sure.....there are others. Appears to be harder and harder to find in some states.
93 Octane Gas - Locations Across USA - Page 5 - Corvette Forum |
Mostly talking about euro cars, which didn't have a cat., but had a pre-muffler. Yes, maybe they were/are supposed to have a cat. installed as part of Federalization, but many have been converted back to their roots of a euro spec beast |
Whether or not the car has a catalytic converter isn't the issue. The engine compression ratio is the main concern, along with the fact that in some areas of the country we experience much greater temperatures than they do in Germany. A 1979 SC doesn't have a high compression ratio and can burn about any gasoline blend. A ROW 3.2 is a different beast.
I don't know what the fuel octane requirements are for a normally aspirated 3.2, offhand. If it's higher than you can buy locally, either setting the fuel quality switch in the Motronic ECU to position 4 or having a custom chip burned for you would seem to be two options. I have experience running a ROW 930 which was intended to use 98 RON fuel and reducing the timing on that car was one way of dealing with the problem. People are used to thinking that you can deduct 4 octane points from a RON value to arrive at an equivalent R+M/2 value, but that's not strictly the case. JR |
![]() It was around 1979-1980 when catalytic converters started to become mandatory for U.S.-sold cars. One of the reasons the 930 was pulled for the beginning of the eighties. Guess I should be glad here we can still get 93. Wish we could get fuel without any effing ethanol though. Take care! Last edited by FrenchToast; 07-06-2012 at 09:09 AM.. |
Diss Member
The only appreciable improvement may be that some brands have improved additive packages for their premium gas that may keep injectors clean to help with long term reliability. ... Or you could put in some Seafoam every once in a while.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
If there is no knock and the timing is not being reduced, increasing the octane will likely reduce power slightly. JR |
While the Euro Carrera has pistons that are quoted as 10.3 compression ratio, they are actually less. For some reason Mahle quotes their piston CR based on zero deck height. Actual measure CR is usually .5 less. So the Euro Carrera actually has 9.8 CR.
-Andy
I have a 1981 911SC and I use 89 octane. 93 is not available in Maine. With every tank of gas I add Marvel Mystery Oil, 104 octane boost, Lucas upper cylinder lubricant and Marine Sta-bil. My mechanic swears by the recipe, and the car's been running great! I do not have a catalytic converter, and I can get 100 low-lead at a local airport, but I'm not sure if that would be good for the car. Anyone know?
Diss Member
It probably won't directly cause any major havoc but I don't like to use "probably" as a guideline for the care and feeding of a motor that costs $10k to rebuild. BTW - If you have a stock US market SC then 89 octane is fine. All the other stuff is just helping the cash flow. STA-BIL is a good idea if the car is driven infrequently. Other then that just buy a quality gas that has a good detergent package. Chevron and Shell are good choices.
Do not run 100 LL in your car. The lead makes white deposits in your combustion chamber and can cause sticking rings.
-Andy
Just go to any auto supply and buy NOS octane booster, should add about 7-9 more octane even though it says 10.
Just don't worry about it. There is almost no 93 in Oklahoma. I can buy 100% gas no ethanol, but 91 is about you can find. It has never been an issue in 16 years of driving.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
