3.6 conversion - how do I connect a "Hammer"
So my Rat Rod is now running and to a point where the engine needs a little TLC. It has some issues like;
  • Runs rouch at cold start, warm it runs pretty good at idle
  • Misses at full throttle accel, so I adjusted the airflow meter spring tension to help this a lot. This is a bandaid though because AFM should not need to be touched.
  • When you stab the throttle quickly (like cruise to WOT) there is a big pause, then the car pulls.
Those are a few of the issues. I know its not the ignition, that has checked out. It could be fuel pressure (installing a gauge this weekend to check). I realize my best bet it to put the car on the dyno, and read the AFR's as see where it is at. The car has a Steve Wong Chip, so I know that part is wonderful.
I also realize I would still be flying pretty blind but, if I could communicate with the ECU though a Hammer or a similar device, I would probably learn a lot that would guide me in my quest to get her running well. Question is what wires do I need, where would they be found in the 3.6 wire harness (colors etc) to connect up a hammer? I did not do the conversation, or I would have left those wires out.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 06-29-2016, 05:29 AM
Chain fence eating turbo
This screams vacuum leak to me.
Old 06-29-2016, 06:29 AM
Platinum Member
dad911's Avatar
964 or 993? which obd?
The info is out there, google "964 OBD" or "993 OBD"
Also found this:
DIY diagnostic reader for OBD1 cars (964, early 993)
Old 06-29-2016, 06:41 AM
964 so ODB 1.
Vacuum leak....well I am looking into that as well. I had one and fixed it.....and nothing changed. I have even sprayed around the engine bay with brake clean to see if I have one (old school hot rodder technique) and nothing seems to change. I do not disagree though....just thinking a hammer would really help narrow my search.
Also found this:
I did search, and did not see that. I also believe it would not be that hard to connect it straight to a Hammer, with the traditional OBDI connector. I searched here and Rennlist, and while I found some info, nothing seemed to be concrete. I would think, but now, someone would have posted a how to with pictures etc. LOL
Old 06-29-2016, 06:49 AM
Platinum Member
dad911's Avatar
how to add OBD plug to 3.6 transplant
How to use an OBDII diagnostic port in a 3.6 transplant.
Old 06-29-2016, 06:58 AM
Clorinated brakekleen through an engine produces phosgene gas. Have fun. Same as welding around it.
206 637 4071
Old 06-29-2016, 11:21 AM
