3.6 conversion - how do I connect a "Hammer"
So my Rat Rod is now running and to a point where the engine needs a little TLC. It has some issues like;
Those are a few of the issues. I know its not the ignition, that has checked out. It could be fuel pressure (installing a gauge this weekend to check). I realize my best bet it to put the car on the dyno, and read the AFR's as see where it is at. The car has a Steve Wong Chip, so I know that part is wonderful. I also realize I would still be flying pretty blind but, if I could communicate with the ECU though a Hammer or a similar device, I would probably learn a lot that would guide me in my quest to get her running well. Question is what wires do I need, where would they be found in the 3.6 wire harness (colors etc) to connect up a hammer? I did not do the conversation, or I would have left those wires out.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Chain fence eating turbo
This screams vacuum leak to me.
Platinum Member
964 or 993? which obd?
The info is out there, google "964 OBD" or "993 OBD" Also found this: DIY diagnostic reader for OBD1 cars (964, early 993) |
964 so ODB 1.
Vacuum leak....well I am looking into that as well. I had one and fixed it.....and nothing changed. I have even sprayed around the engine bay with brake clean to see if I have one (old school hot rodder technique) and nothing seems to change. I do not disagree though....just thinking a hammer would really help narrow my search. Quote:
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 06-29-2016 at 05:52 AM.. |
Platinum Member
Clorinated brakekleen through an engine produces phosgene gas. Have fun. Same as welding around it.
Thread Tools | |
Rate This Thread | |
