clutch shaft seal: why do I need three of these
In the parts catalog they require three of these seals anyone know why? All the diagrams show only one.
Porsche 911 & Carrera Clutch & Flywheel - Page 7 915-301-139-00-M30 Throw-Out Lever Seal (sold per each), 911 (1974-77, 1 req.), 911 (1978-86, 3 req.), 911 Turbo (1976-77, 2 req.)
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
I put 2 on the throw out arm (above and below where it attaches) and one on the lower part of the shaft shown in the diagram. I believe the 101 projects tells you there are supposed to be 2 on arm itself. When I took my trans out it only had 1 on the arm and the replacement trans I got only had 1 or maybe 0. it is really just to keep grime/dirt out of the shaft and both worked fine like that.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Same as mine........
Those are just dust/dirt seal. Two (2) will be just fine but they are not that expensive. So having an extra seal on top would be better IMHO. Tony |
one above the release fork in the bellhousing and the other two above and below the long release arm.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-12-2012 at 02:10 PM.. |
They can make it tough to catch the circlip. I had a real struggle with mine but eventually got it by using a socket and a persuader to seat the arm over the circlip groove.
Ken 1986 930 2016 R1200RS |
