Fleabit peanut monkey
Bob Kontak's Avatar
Here are some links to chew on. Probably a lot of repeats from what has been stated here.
Replacing 'all' suspension bushings - 911SC
911 sc upgrades
Grady Clay comments in this one.
Got a bit of money...what would you recommend as SC upgrades?
CIS to EFI Conversions?
http://forums.pelicanparts.com/porsche-911-technical-forum/33313-what-can-you-do-80-sc-get-better-performance.html
Old 08-07-2012, 08:45 AM
HRHski
HRHski's Avatar
Without spending huge amounts of money your 911 SC can run with and be more fun than most modern cars and definitely cars of the era up to 1994. I have run side to side with a 3.6 Carrera up hill, at altitude, with my 82 911 SC. Of course the 915 transmission is geared lower and after 80 mph this advantage, is gone you are no longer in the game with the 3.6 liter with the G50 transmission. But how do you do this? First, reduce weight, race seats, fiber glass bumpers and remove air conditioning. Wheel up grades, make them light. Exhaust, cat removed. If you have extra cash, 964 cams, ti connecting rods, larger air intake box, MSD ignition, Carrera up grades and Turbo valve covers. Suspension, all Turbo upgrades, and torsion bars, Bilsteins, lower chassis. Now you have it, with good tires you can run with most modern equipment, if you can drive a 911 well.
www.harbskisystems.com
http://harbskisysems.blogspot.com
Old 04-14-2014, 03:04 AM
Halm's Avatar
Absolute "must have" is the pop-off valve in the air box.
I have owned SC's for close to 20 years now. And IMO, the best mod for the buck is a Fabspeed cat by-pass. It saves a few pounds, it may eliminate an old, clogged cat, but most importantly it lets through the beautiful noises the 3.0 makes.
As for brakes, Call Steve at Rennsport in Portland and order Mintex Red Box pads.
For street driven car, that is all you need. . . But probably not all you want.
'17 Cayenne
Old 04-14-2014, 06:01 AM
I hate to have to point this out but you guys are replying to a thread from a couple of years ago...
JR
Old 04-14-2014, 06:19 AM
Only two years? Seems like its even more relevant today. More valuable, more special, more sweetness in many aspects. Simplicity is even more distinguished than ever.
Diverdan
Old 04-14-2014, 10:01 AM
Eva
911SauCy's Avatar
Originally Posted by trak ratt View Post
complete tune up to include valve adjustment
turbo lower valve covers
if early SC upgrade fuel lines
fuel filter
replace all vacumm lines
drain gas tank, clean screen replace gas lines to pump
chain tensioner upgrade
renewed bushes front and rear
remove BIG washer on front struts
lower to Euro height and realign
rebuild calipers
SS brake lines
SSIs and 2 in, 2 out muf
new Bilsteins front and rear
new shifter bushes front and rear
repair the side oil lines
upgrade oil cooler
7x9 fuchs w/225 & 245 tyres
I have a '78 SC and did everything here aside from tensioners, SSI's and stainless brake lines.
I've also lightened the car ~215lbs, basically removed cat and muffler, and a number of other non-performance enhancing but overall "mods".
It's the most visceral thing I've ever driven and it's always sad to watch the garage door close behind her...
HOWEVER, You must prioritize as this has cost close to $11k...and the SSI's and Tensioners aren't "low-buck" upgrades by any means...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-14-2014, 11:09 AM
Hopelessly Addicted
Porschephanatic's Avatar
Thumbs up
JR
Subscribed. Thread still relevant!
'81 SC Targa
'86 944
'49 Ford F-3
'13 Yamaha FZ-1 (Adrenaline Machine)
Old 01-25-2016, 04:30 PM
Reiver
Reiver's Avatar
First I'd get it back to what it was....replace bushings in the A arms, sway bars, trailing arms, spring plates, check your shocks for wear. Inspect front T bars for rust/pitting.
While doing this I'd change the sways to Carrera sways 22/21 from the SC 20/19.
Steering should be tight, replace the bushing in the column under the steering wheel, upgrade to turbo tie rods.
Replace/inspect all shift bushings at the gear lever and coupler.
Replace tranny/engine mounts...they degrade.
Dump the almost worthless AC (some do, some don't...I did as I wanted a lighter car as 100 lbs.= 10 hp.) ok, that's not a must do.
Make sure your wur is operating at spec./same for the fuel head.
Adjust AFR and a good tune up w/valve job....get a leak down for a base number.
Then,
Dump the cat and get SSI's, a stock style Dansk banana muffler two in one out will actually be the best for torque and street HP.
IOTW, get it properly stock and running as it should, handling as it should then decide on upgrades.
Have fun.
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-25-2016, 04:50 PM
If you plan to do much drivers ed/tracking, an auxillary oil cooler is a must. SC's are way under cooled (oil) when driving aggressively over a period of time.
2016 Porsche GTS Club Coupe (60th Anniversary)
2007 Porsche GT3; 2014 Porsche Cayman S
1981 Porsche 911 SC; 1988 Porsche 944 Turbo S - Silver Rose
2010 Audi Q7 TDI; 2002 Audi A6 4.2 ; 1971 El Camino; 1966 Chevelle SS 396/360 HP; Spec Miata racecar
Old 01-26-2016, 05:25 AM
I didn't go down the oil fed tensioner route. I replaced with stock. I discussed this at length with my local dealer who pointed out that oil fed ones can and do fail as well. He also believed that Porsche supplied originals are now improved over ones fitted when my car was new and I should expect them to last longer. As the originals lasted 75k miles and my mileage per year is low, I will be about 125 years old before they need doing again. So I have a tidier engine bay, less joints for oil leaks, and a few dollars left in the kitty from the cost saving!
Old 01-26-2016, 09:19 AM
Reiver
Reiver's Avatar
Agree, I've a Carrera rad cooler unit/fan and that is the way to go. The block off and forced air make a dif
De Oppresso Liber
Old 01-26-2016, 09:53 AM
I have a IROC style front valence. Does it make more sense to run a center mount cooler in tandem with the trombone or should i upgrade to the carrera cooler and call it a day?
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 01-26-2016, 10:12 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Here was my list. Many were already done, lucky me. Bold are stressed items that I think often are overlooked.
930 tie rods
Hydraulic tensioners
Shifter bushings and upgrade to solid linkage by input shaft
930 valve covers on bottom
new headlight switch
new turn stalk/switch
hl relay kit
fuel sender
oil temp sender
ground strap by transmission (oil and corrosion = too much resistance)
Valve adjustment
free-flowing exhaust
Brake fluid flush (every 5 years or so if you drive it much)
adjust the damned brake pedal so you can reach it and throttle at the same time
Recaros
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 01-26-2016, 11:14 AM
I have a center mounted oil cooler. I bypassed the stock cooler. Oil temp is rock solid regardless of the exercise mode.
Old 01-26-2016, 11:26 AM
My 2 cents......(in addition to the above considerations)
- volt meter (I prefer analog/real meter)
- seats / belts that hold you in place.
- head stud check (every oil change)
Old 01-26-2016, 11:44 AM
Hopelessly Addicted
Cool
I didn't go down the oil fed tensioner route, either. My mechanic recommended and installed Turbo tensioners with the "anti-collapse collars" 15 years ago, and I have had no failures.
The MSD ignition and SSI's / Dansk dual-in/dual-out Sport muffler made a HUGE difference on the butt dyno.
I am going to upgrade the oil cooler this year, even though I don't track the 911SC.
I've heard so much about the unavailability of parts, and the devastating effects of ethanol on the CIS systems, I've considered installing an EFI system, and cleaning and storing the CIS for future owners (son and grandson). Thoughts on EFI?
'81 SC Targa
'86 944
'49 Ford F-3
Old 01-26-2016, 02:50 PM
Banned but not out, yet..
RSBob's Avatar
The previous posters have great advice. I did SSIs and a sport muffler, but also pulled about 150 lbs of dead weight out of it which gives you faster acceleration and braking.
I pulled the center console, worthless AC, back seat backs, heater blower motor when backdating heat, changed bumper shocks for crush tubes, pulled the spare and added Fix-a-Flat and tire plugs, switched the heavy metal engine cover for fiberglass and lost the rear overriders. Other heavy weight items are the power seats at about 50lbs each. You can replace both for half the weight. Weight is the enemy. The more you lose the faster your car accelerates due to less mass and most of this is free other than the rear deck lid.
Old 01-26-2016, 07:52 PM
16x9 fuchs on the rear
Old 01-26-2016, 07:59 PM
RSBob's Avatar
Was returning to edit my post when Ferraripete beat me to it, but I was going to add 16X7s in front too. Actually mine are 17s just to have a better selection of tires.
Old 01-26-2016, 08:07 PM
Reiver
Reiver's Avatar
I'd just do the Carrera unit...can't imagine needing any more cooling for a 3.0. I run my '83 euro in 110 degree ambient Az summers (75 mph trip to/from Phx) and don't see 210 often. That is without the fan going (I have it switched so I control it). At hot idle summer I'm still at 1 bar plus. The fan does a great job in stop/go heat.
This time of year I block off the scoop I have in place.
De Oppresso Liber
Old 01-26-2016, 08:54 PM
