Air Cooled
WEVO shifter with dual springs, and their precision shift joints. It was my first mod and made a huge difference in enjoyment.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
SEVENT9
Awesome thread - subbed!!
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html |
I would start with nothing but proper maintenance.
Then do Track Days. And AX. A lot of them. Then do mods, one at a time, so you really feel the change each mod gives. suspension/set up first. Lighten second - this could include the SSIs may need to retune susp/ride height if you lighten a lot then do your engine internals if needed. These cars are so fun at their limit and driving a slow(er) car fast is more fun than a fast car slow. If you can turn the same time driving 9/10s on track it is WAYYY more fun that turning the same time at 6/10s in a faster car. |
Under the radar
So little has changed in the last 5 to 6 years......
A good list...........
to start with. I would add SSI exhausts to the list. If not already on the car, I would add 16x7" front wheels and 16x8" or 9" rear wheels. A front strut brace would be helpful as would adding a short shift kit. I used the Porsche short shift kit on my SC and like it very much. Happy hunting!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
old thread, but yo can address 2 issues w/ one change
while a 3.6 is nice and gains you ~50 lb-ft of torque and losing 100# is like adding 15lb-ft of engine torque, and regearing will have a similar effect all are intrusive and expensive. Change to 15" wheels can add ~45lb-ft(near what a 3.6 adds) here are a couple of possibilities ![]()
82 911SC mods:
Oil fed tensioners Airbox pop off valve Turbo tie rods H4 headlights headlight relays air conditioner delete Otherwise stock and just fun to drive.
JB Noriel 82ChiffonSC IG @82_901sc |
Keep the rev's up.
my list:
complete tune up to include valve adjustment renew all K-Jet seals, ultrasonic cleaning of parts new injectors replace all vacumm lines chain tensioner upgrade upgrade oil cooler renewed bushes front and rear RS strut brace (welded in) turbo tie-rods lowered to 63cm front, 62cm rear rebuild calipers (thicker rotors need 3.2 calipers) Zimmermann drilled discs and Ate pads SS brake lines SSIs and 2 in, 1 out Dansk Sport muf new Bilsteins B6 Nürburgring front and rear WEVO shifter & PJS coupler 7/8x16 w/205 & 225 tyres weight droppet: - lighter battery (now 10, instead of 23 kg) - removed rear seat sound deadening - removed stereo - removed AC - removed rear heat blower - ducktail fibre glass - removed rear foldable rests
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Senior Advisor
nice^^^ that should keep you happy.
08 Cayenne Turbo |
And what looks nice. Is to backdate the heating system. This is removing those awful brown hot air hoses etc.
Banned but not out, yet..
First I backdated the heat and then backdated the induction system to PMOs with EFI. More grunt and a great induction sound. Retro-mod.
An air cooled refrigerator. ‘Mein Teil’ |
Black and Blue
ok...here is the list of things I did to my 82 last year or so
21/28 Torsion Bars Revalved shocks to match OEM Sways from 86 Carrera new bushings new rubber/neatrix bushings in A-arms and rear torsion area new wheel bearings front and rear rebuilt calipers hawk HPS pads sweet assed alignment had my CIS fuel distributor rebuilt along with WUR, 6 new injectors new fuel filter, Cap, rotor, spark plugs, and Magnecores momo prototipo radio delete with block off plate to do: SSI Heat Exchangers with Dansk sport muffler Adjustable rear sway drop links
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
it all depends on what you want...
for street? i think SC's are now starting to become quite old, and so a lot of things are going to start breaking down, or at least deteriorating. If you buy a stock car now, be prepared for a lot of cost and time to make it run nicely. replace/repair everything that doesn't work or is too old: tires, fuel hoses, suspension, vacuum hoses, brake lines, discs/pads, light bulbs, relays, wires, etc...and if your CIS is not perfect (and most of them aren't), add another couple of 1000 to make right. costly. Other than that, MUST mods? i've done lots of mods, but not one of them is really MUST. Most of them were done out of another form of necessity: things were broken. Stock it is quick enough, it brakes well, steers great, sounds good, suspension feels solid, it is gorgeous to look at. If i had to put my mods (not repairs) in order of most worthwhile and also considering budget: nardi steering wheel (best mod for me personally, cheap and wonderful) take off A/C (non working) wideband 02 sensor and afr gauge (peace of mind) volt gauge (peace of mind) heater backdate (get rid of a lot of junk, and heater still works as well as before) repro lightweight rear light units to replace the rotten heavy old ones hydraulic tensioners (peace of mind) bitzracing EFI (to replace rotten CIS) classic retrofit CDI+ (peace of mind and a bit tuneability) SSI's (to replace rotten heat exchangers) (the car already had plastic bumpers, rocker cover delete and some other bits) I'm sure the car is quite a bit quicker now, but you get used to it quickly and even with EFI and SSI's, it is deffo not night and day with CIS and stock exhaust. It is boring, but i would now put my money in good tires first. Maybe some new seatbelts too cheers
before: '69 Porsche 911T bahama yellow now: 1981 911 SC Targa winered |
Black and Blue
I would have to dig around for the alignment sheet, ill see if its in the glove box.
ride height is 1/2 inch under Euro in the front and back with RUF Speedlines, Bilstein shocks re-valved at Elephant. Stock motor with JE 9.5 pistons with a "re-nikasil" from EBS, headwork by EBS, Rockers service at German Precision, New Rocker Shafts, RSR Seals, Crank Serviced and drilled by Armundo, Jerry Woods rebuild of Distributor, CIS and WUR rebuild at CIS Flowtech, the list goes on and on like my Credit Card Bill
Hey @wreckah,
I'm curious about these two things you mentioned: Quote:
I've never heard of the wideband O2 sensor and afr gauge. Can you elaborate? Thanks! Todd |
Launch button.
Under the radar
