Throw it on the ground!
Bad Remanufactured Bosch Alternator saga 1987 3.2
Have read stories of folks getting bad reman alternators on this board and it just happened to me. Here is the story:
Have had issues with the battery holding a charge over winter (alt light flickering and low battery charge) Ordered a reman Bosch alt from Pelican several weeks ago in anticipation of change out. In the meantime, I connected the CTEK trickle charger nightly to keep charged. Off to Winston-Salem for a week long business trip 2 weeks ago (did not get a chance to swap the alt before I left). Staying with family in Asheville - drove to Asheville from Winston a week ago Fri and the battery died, left me stranded with a rear tire blow out from hitting debris on the shoulder. Flat bedded to a shop in Asheville. Tests revealed the alt to be "good" and battery to be "dead". New battery, new tire, oil change, valve adjust, new plugs, dizzy cap and rotor, $1,400 and one week later headed home to Atlanta the following Friday and new battery died and left me stranded 10 miles from home. Had to have it flat bedded again!
Installed the reman alternator yesterday and the alternator light remained on indicating charging problems. Up to the dealer today for some troubleshooting. They pulled the new alternator and determined it to be bad - alternator was good but the diode connecter bar on the exciter connector (blue wire) had a bad spot weld and was therefore inop. They pulled the piece off the old alternator to fix but in doing so they noted that the diode connecter on the old alt was bent too far towards the voltage regulator and had a crack in the plastic connecter and was therefore shorted and was not charging. So neither alt was working properly. Go figure. Never would have figured this out on my own and yet another example of a bad reman unit out of the box. Bosch quality control prob - bad spot weld. I'll call Pelican tomorrow to see if they will swap it out with a replacement or replacement part.
Will post pics of the bad part to add to the boards for reference.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-27-2012, 07:14 PM
yuuuup.
206 637 4071
Old 02-27-2012, 07:28 PM
Spoke to Pelican today. They are sending a replacement out right away but I have to pay for it and will get a credit for the bad unit as well as the core credit upon return of the old alt. Will still post pics of the bad part shortly for reference.
Mark
1987 911 Coupe
Old 02-28-2012, 07:49 PM
gtc gtc is offline
abides.
gtc's Avatar
I got a bad one last time also. It's one reason I like to buy this sort of stuff locally... no shipping hassles when you get one that was rebuilt poorly.
Graham
1984 Carrera Targa
Old 02-29-2012, 10:05 AM
kodioneill's Avatar
Agreed, or have it rebuilt locally.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-29-2012, 10:26 AM
Exactly. I have gotten a few bad alternators, and it's much easier to drive back to the store and swap out another one.. NBD.
Old 02-29-2012, 10:32 AM
I have a local guy that can fix an alternator cheaper than a Bosch Reman, and he knows what he is doing so it works the first time. He does starters as well.
Old 02-29-2012, 11:10 AM
Here are the pics. The exciter connector plate with the diode and faulty spot weld is actually attached to the old alternator in this pic after the Porsche tech swapped it out to get me back on the road.
Mark
1987 911 Coupe
Old 02-29-2012, 03:55 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
As much as I like Pelican's parts, I live on the other side of the country and the shipping cost of an alternator isn't trivial.
So, I took a chance and sourced the replacement alternator for my '87 locally. The FLAPS (Advance) not only had the unit (surprise!) but supplied a re-manufactured unit with a test report. Interestingly, it was a Paris-Rhone, not Bosch. I checked and so was the original unit.
So far, and it's been a few years, so good. But I don't drive the car all that much.
Old 02-29-2012, 06:56 PM
Lorenfb's Avatar
"Interestingly, it was a Paris-Rhone, not Bosch."
There was never (nor is there now) a Bosch alternator for the 911 3.2. They all were/are
Paris-Rhone (Valeo) as was the '82/'83 911SC. They just come in a Bosch box, and who
knows who the actual rebuilder is, i.e. Most likely Bosch subcontracts the rebuilding.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-29-2012, 07:38 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Interesting point. My reman unit did not come in a Bosch box, but one labeled with the Paris-Rhone logo.
There have been other discussion on this:
Alternator question: Paris Rhone and Bosch interchangeable?
(I always wondered at any possible connection between Le Rhone engines and Paris-Rhone alternators.)
Old 02-29-2012, 07:52 PM
Lorenfb's Avatar
"Respectfully.....retail outlets need to offer remans......bidness 101.....
It doesn't matter who makes them to begin with. The 'rebuilders' do it on the cheap. The remans don't have to worry about the customer coming in and kicking their ass when it fails in BFE. The retailer blames the reman and the customer gets a 'free replacement' less labor...."
Do what? It's getting late, right?
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-29-2012, 09:13 PM
AAARRRGGHH Replacement alternator received today - damaged in shipment. Naturally the part it need is what was damaged. WTF?
Mark
1987 911 Coupe
Old 03-01-2012, 12:11 PM
Saga continues. After several months of charging issues, battery discharges and no-start situations had system tested and diagnosis was 11.4V under load (should be 13.5+V) and 0.00V under load for alternator (WTF?). Replacement under warranty on its way from Pelican...:-(...just sayin.
Mark
1987 911 Coupe
Old 07-25-2012, 02:59 AM
I took my original alternator to Sleepy Hollow Rebuilders in Cumming, GA last April. They rebuilt it over a weekend for $125.
Old 07-25-2012, 05:01 AM
Also took my alternator to a rebuilder, sleeved the rear bearing housing, 2 bearings replaced for $50 in one day. I put a new $25 voltage regulator and brush assembly myself and the alternator is refreshed.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 07-25-2012, 05:49 AM
My local rebuilder refused to rebuild mine. He called me about a week after i dropped it off and said he can't get the good parts for them anymore and refuses to use "cheap Chinese crap" because he's had too many come-backs.
I bought a pricey new (not reman) one from our host... So far so good.
Ken
1986 930 2016 R1200RS
Old 07-25-2012, 07:25 AM
Chain fence eating turbo
Had mine rebuilt by an old friends dads alt/starter repair shop replacing both slip rings, voltage regulator and one rectifier plus fully soda blasted with new hardware for $150.
Works fine.
Old 07-25-2012, 07:49 AM
KNS KNS is offline
So, are brand new alternators just made out of new "cheap Chinese crap"? Or, are they built somewhere else? I've got a Bosch reman in my car and so far so good but if the day comes to replace it I'll try to get it rebuilt locally.
Kurt
Old 07-25-2012, 09:07 AM
Originally Posted by mthomas58 View Post
Saga continues. After several months of charging issues, battery discharges and no-start situations had system tested and diagnosis was no-charge under load for alternator. Replacement under warranty on its way from Pelican...
Received replacement alternator from Pelican and dropped the car off at the dealership to troubleshoot last week. After going through several alternators since Feb I was not totally convinced the problem was the alternator. Turned out the reman alternator was bad - they said it looked like it had overheated as the internal field looked like it has cooked. They checked/cleaned all of the circuit connections and replaced the alt with the warranty replacement from Pelican and all is now good.
Mark
1987 911 Coupe
Old 08-16-2012, 03:25 AM
