thebondman's Avatar
Send a message via ICQ to thebondman
Need advice on what power source (safe) to use for a Jacobs Omni Magnum
I'm looking for a good 12 Volt source located in the engine compartment to power the Jacobs Omni Magnum. Any ideas/recommendations?
Jacobs Omni Magnum
"If you're not living on the edge, then you're taking up too much space."
My 1979 930
1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse.
1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines
2003 Jetta Wagon GLS 1.9L TDI
1993 GMC Jimmy 4x4
St. Louis PCA - Member
Kirkwood H.O.G. Chapter #2573 - Member
Gateway H.O.G Chapter #1337 - Charter Member
Old 05-28-2002, 02:43 PM
Irrationally exuberant
ChrisBennet's Avatar
Is it too late to return the it?
Old 05-28-2002, 04:11 PM
thebondman's Avatar
ANYONE?
My 1979 930
1993 GMC Jimmy 4x4
Old 05-29-2002, 04:43 AM
Dept store Quartermaster
lendaddy's Avatar
Well I just hooked up my MSD and I sed the power at the rear fuse panel. I don't know about the Jacobs unit but MSD only draws like 5.8 - 6.7 amps so I don't see a problem. Also it is constant 12v . Good luck.
Cornpoppin' Pony Soldier
Old 05-29-2002, 05:45 AM
Use the 12V wire that you disconnected from your stock coil primary, that's what it's for.
Cheers,
Joe
Old 05-29-2002, 09:03 AM
thebondman's Avatar
This is NOT a coil.
My 1979 930
1993 GMC Jimmy 4x4
Old 05-29-2002, 09:09 AM
