awdbandito's Avatar
Which CV boot do I need?
Which CV boot kit do I need?
This is for a '75 911S with a build date of 5/75. I'm not sure which boot I need.
Here are some pictures of the offending CV joint.
I just want the boot, grease, and clamps.
Thanks,
'12 Cayman R
77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone
Old 08-26-2012, 11:50 AM
plymouthcolt's Avatar
Here Porsche 911 & Carrera Axles & Bearings - Page 1
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 08-26-2012, 12:27 PM
using 4 10mm cap bolts uses 901.332.293.12 plus the bands to hold them in place
Bruce
Pelican has the whole kit containing everything..very convenient.
Bruce
Old 08-26-2012, 12:28 PM
michael lang's Avatar
But if you are going to go through the trouble of taking the axle shaft out to replace the one boot, you might as well do the whole axle shaft. I would just suggest to be super careful to keep the bearing assemblies intact or you could have more problems then what you started with.
Mike
'89 CARRERA
#402
Old 08-27-2012, 12:43 AM
awdbandito's Avatar
It looks like I have more than four bolts on the interior of the hub. Is this what you are calling a cap bolt?
Bruce
I have done many axle changes and boot replacements on other cars, but never the 911. I feel like I can do it without causing damage. I'm just trying to figure out what part I need. I don't know what I am looking for.
Thanks,
'12 Cayman R
Old 08-27-2012, 06:01 AM
If you have 6 cap bolts they are likely M8 x 50 mm. In '75 there was a mid-year change with the Cv's so I'd call our host to see which one you need.
Keith
Old 08-27-2012, 08:53 AM
