SC 1982 - Parking brake light permanently on
Hi all,
I have already been disassembling the hand brake to verify if the brown wire was disconnected... it was not.
Anyone has a clue of what might be the reason?
K-Jetronic student
Old 10-28-2012, 09:48 AM
ROW '78 911 Targa
timmy2's Avatar
Do or did you have a rear brake light burn out or not lighting completely that you fixed recently?
On my car I have to disconnect the battery to clear the latched relay for the brake light after fixing a loose or burnt out brake lamp.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-28-2012, 09:55 AM
Fb = M/S
aoncurly's Avatar
The brake light on is indicative of a pressure problem with the brake system. Mine was on for a long time, and it turned out my Master Cylinder was leaking. Replaced the MC and the light went off. Check your Master Cylinder and all brake lines/hoses.
Old 10-28-2012, 09:56 AM
Recreational Mechanic
Nickshu's Avatar
Bob: Try the parking brake
Doug: Take off 'eh, the parking brake never worked
Start watching at about 2:25:
Strange Brew 1983 "no point in steering Now" - YouTube
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 10-28-2012, 10:28 AM
Thanks for the input.
Master cylinder was new and all the bulbs are working properlly...
I will try to reset the relay.
Thanks all.
K-Jetronic student
Old 10-28-2012, 10:50 AM
On my '83 there is a switch under the parking brake lever. Cant check on my car but from memory the lower edge of the lever pushes on the switch such that it is closed when the parking brake is released. The switch has some vertical movement and is held in one place by a locking screw. Mine is at the highest point of travel but I still have the problem of the light staying on. If I release the parking brake then push down on it the light goes out but after driving for awhile the brake lever lifts off the switch just enough for the light to come on. Hope you find a solution. I guess you could always black insulation tape over the dash light?
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 10-28-2012, 12:26 PM
djcdmv's Avatar
Do the SCs have brake pad wear indicators as my Carrera has? If so, that would illuminate the same light.
I'm very determined to help somebody on Pelican after all the help I have received from this board...
Dave
Black 1985 911 Carrera M491
Old 10-28-2012, 02:43 PM
Nickshu's Avatar
Mine does not, but I think low brake fluid level might turn this light on as well.
Old 10-28-2012, 02:50 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
sc's are sensor free. no brake fluid or brake pad.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 10-28-2012, 08:43 PM
wwest's Avatar
That's often an early sign of battery overcharging VR/alternator problems.
Old 10-29-2012, 07:25 AM
tharbert's Avatar
Does the 82 have that reset button on the MC like earlier MY's?
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 10-29-2012, 07:41 AM
Brake light...
I replaced a leaking caliper ('82 SC) and my light went out. I think the system senses pressure problems as well as when the e-brake is left on.
Old 10-29-2012, 10:03 AM
