Pro and con of leaving O2 sensor disconnected
Hi guys - I brought my '74 to a well respected shop to get their help on a surging issue that they tracked back to the O2. They simply disconnected it - and she runs better now. Any issues with leaving it disconnected? I know opinions vary here...
Thanks in advance for the coaching.
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 09-25-2012, 06:19 AM
kodioneill's Avatar
With a Motronic 3.2 I wouldn't disconnect the O2 you're just masking some problem.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-25-2012, 06:24 AM
I agree. Fix the real problem and hook up the O2. It will keep you engine running properly.
Old 09-25-2012, 06:45 AM
RETIRED
Joe Bob's Avatar
The sensor is cheap, replace it....it's important to the DME's proper operation.
2012 ML350 3.0 Turbo Diesel
Old 09-25-2012, 07:03 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
disconnecting it will only cause it to run rich, so if that solved your problem you could be running too lean--run a search on lean running problems
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 09-25-2012, 07:05 AM
theiceman's Avatar
so much for all these " well respected " shops . surging is actually due to being rich or of courrse the compensation is not working correctly.
O2 sensors are maintanance items anyway so start fresh and replace it, then start troubleshooting.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-25-2012, 12:33 PM
Completely agree,...these cars were designed and intended to run closed-loop and suffer accordingly when the oxysensor is disconnected.
Your shop needs to perform some diagnostic tests to find out what the root problem is.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-25-2012, 01:22 PM
AutoBahned
RWebb's Avatar
one tidbit to add -- as the O2 sensor ages, the response slows down -- possible that fluctuations are due to the computer trying to compensate for slow response
the sensors last a LONG time - but are simple to replace and not too spendy; also be sure the coax cable is in good shape (I'm not familiar with the new-fangled 911s but the above is based on your typical German car of this vintage)
Old 09-25-2012, 01:49 PM
I can't see a pro in leaving the O2 sensor disconnected. The motronic will not get the correct signals it needs to have your engine run at best power and efficiency. The sensor is a 60K mile service item and can be changed within half an hour.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 09-25-2012, 01:58 PM
KTL KTL is online now
Schleprock
KTL's Avatar
It may run better in open loop mode but i'll bet money that your fuel mileage drops like a rock.
The only way you can have a 3.2 work properly w/out an O2 sensor is to have a DME chip mapped like the European cars. Euro 3.2 engines have no provision for O2 sensor.
Kevin L
'86 Carrera "Larry"
Old 09-25-2012, 02:11 PM
T77911S's Avatar
there is no pro to run it not connected.....well.....cost of fixing what is wrong.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2012, 09:58 AM
