response by motronic to cat delete with o2 sensor
Hello- If you have an 86 3.2 motronic managed engine with a cat delete pipe but with an o2 sensor-what is the response to the o2 sensor readings? I am wondering - will the motronic will adjust to the readings by altering injection timing or by going leaner or richer? If you run for an extended period with this setup-is there a downside? Thanks in advance.
I'm no expert but the o2 sensor is before the cat so why would there be any difference?
Justin 84 Carrera Targa 98 F-150 4x4 |
Banned
Thanks for the answers!
