Diagnose Play in Steering Column
Had my 930 out of commission for a couple of months and got it up and out today. Noticed today that I have about a 1/4" of up and down play in the steering column. Had not noticed that previously and had not done any work on the steering. Before I get in and locate the problem does anyone have and idea what is going on? Thanks.
At the steering wheel itself, or lower down? I know when I got my 911, not even a month after, I had the same thing. Turns out the little plastic piece responsible for guiding it where it sits on the bearings in the column broke into a bajillion pieces.
Thankfully, there's these neat little sleeves that you insert that take their place and aren't plastic. Problem solved. Porsche 911 & Carrera Miscellaneous - Page 17 I'd take the steering wheel off though, since you can look inside and look past it to see if the plastic piece is busted up. If it is, and you can see it jiggling up and down, that's your issue.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
ROW '78 911 Targa
From what I've read, go for the Mitch Leland repair sleeve.
Installed Mitch's sleeve last month, FAR better than the factory replacement part and easy to install
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Yes, the play would appear to be right behind the wheel. Sounds like the Mitch Leland sleeve is the cure. Thanks.
Mitch's bushing is a great and simple fix and upgrade. If the entire steering column is also loose there are 2 bolts just inside the dash that hold the upper column in place. Mine were loose enough that I could back them out by hand. They are sheer bolts (round with no way to torque them) and I replaced them with Allen head bolts, some Loctite and snugged them down. The combo of a new bushing and tight new bolts fixed my column 3 years ago and I haven't had any further issues
Ken |
