PhD on Pending Projects
Getting the RSR Tribute to run again... need to clean the injectors. How much air pressure to clean them without damaging the internals of the injectors??
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Yes, I took them out, cleaned them on the outside, running some carb cleaner, dipped in gas while I type this... would like to run some air through them to make sure the internals are working before I put them back.
And yes, installing a new fuel filter as well
ASE Master Tech - 35 yrs
you can buy a inexpensive device called an "injector inspector" which pulses the injector, (i don't recall the brand - it's not on the gizmo)
then set up a fuel pump with a hose connected to the injector nose and pressurize it, (i use a late 914/vw "bullet style" that has one inlet & one outlet - it produces 100psi unregulated) turn on the tester & it will backflush this is especially necessary if you ever get fine rust or dirt into your system .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
RETIRED
Bottle of Techron, Sea Foam or other gas additive after re-installation.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thank you all!!
Fleabit peanut monkey
Ain't no pulsin' on them injectors. Pressure only.
1981 911SC Targa |
I scored some 930 injectors in a box of 930 CIS parts. I wired the pintles open, ran the ultrasonic cleaner for two weeks solid with the heater on and changing the cleaning fluid as often necessary - like whenever I could no longer see the injectors getting cleaner.
Some of the stuff that looked like rust turned out - after about a week - to be fuel varnish... I backflushed (from the manifold/pintle end against the direction of fuel flow, to lift anything off the internal screen) several times. Any Porsche or MB place that works on CIS cars should have a CIS injector tester that lets you measure the crack pressure and observe the spray pattern. I junked two out of six - which, at $140 a pop for RoW 930 injectors, I thought was kind of a result....
'77 S with '78 930 power and a few other things. |
Red Line Service
Yes a Bosch CIS injector tester and some mineral spirits will fix a lot of injectors. We use our tester ALL the time. We still replace injectors but many times you can clean them. If your going to store them, put a little ATF through them before you put them on the shelf.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
We usually send our CIS injectors to a local diesel repair shop - might check that option. For the newer 911's with the electronic injectors, we send those to Witchunter in Seattle.
angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
AutoBahned
yes, any Cummins shop can do it - Or. Fuel Inj. is the local go to place here
Some day I'm going to use one of several spare brake master cylinders to make an injection tester. Mount with a lever, put in a pressure gauge, and find the fittings needed to screw onto the injector. Use any old container as a reservoir for the fluid.
some day. |
Test opening pressure......
Check the opening pressure. I segregate or classify the CIS fuel injectors according to the value by which it starts to spray uniform mist pattern. Group I (35 - 39 psi.), group II (40 - 45 psi.), and group III (46 plus psi.). They should not drip at standby and produce uniform mist spray pattern to pass the test. Group I is classified as VERY GOOD, group II as GOOD or ACCEPTABLE, and group III as REJECT. While group III fuel injectors could still make the engine run, I avoid using them. Tony |
Free minder
I cleaned mine in an ultrasonic bath of IPA. They came out as new.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Right now I think I have a fuel pump issue... but I did not have the time to check everything well before getting on a plane... I will spend Sunday troubleshooting the fuel system. Car used too run fine but the rust in the original tank took out two pumps before I figured out what it was... a new tank later... I need to go over the system again. Thanks
Was it the beer or the ultrasonic that did it?
1981 911SC Targa |
