PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Question 1983 SC - How to clean injectors?
Getting the RSR Tribute to run again... need to clean the injectors. How much air pressure to clean them without damaging the internals of the injectors??
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 10-13-2012, 08:07 AM
wachuko's Avatar
Yes, I took them out, cleaned them on the outside, running some carb cleaner, dipped in gas while I type this... would like to run some air through them to make sure the internals are working before I put them back.
And yes, installing a new fuel filter as well
Drive safe!
1967 - Porsche 912
Old 10-13-2012, 08:08 AM
ASE Master Tech - 35 yrs
larrym's Avatar
you can buy a inexpensive device called an "injector inspector" which pulses the injector, (i don't recall the brand - it's not on the gizmo)
then set up a fuel pump with a hose connected to the injector nose and pressurize it,
(i use a late 914/vw "bullet style" that has one inlet & one outlet - it produces 100psi unregulated)
turn on the tester & it will backflush
this is especially necessary if you ever get fine rust or dirt into your system
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-13-2012, 08:37 AM
RETIRED
Joe Bob's Avatar
Bottle of Techron, Sea Foam or other gas additive after re-installation.
2012 ML350 3.0 Turbo Diesel
Old 10-13-2012, 08:41 AM
wachuko's Avatar
Ok... I did it manually with 75psi and they are cleaning well and working... I just want to get it started. New booths, o-rings, etc. after I drop the engine for cleaning, going over the top seals, and other small stuff.
Thank you all!!
Drive safe!
1967 - Porsche 912
Old 10-13-2012, 08:58 AM
wachuko's Avatar
Techron, absolutely!!
Drive safe!
1967 - Porsche 912
Old 10-13-2012, 08:59 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Ain't no pulsin' on them injectors. Pressure only.
1981 911SC Targa
Old 10-13-2012, 11:36 AM
I scored some 930 injectors in a box of 930 CIS parts. I wired the pintles open, ran the ultrasonic cleaner for two weeks solid with the heater on and changing the cleaning fluid as often necessary - like whenever I could no longer see the injectors getting cleaner.
Some of the stuff that looked like rust turned out - after about a week - to be fuel varnish... I backflushed (from the manifold/pintle end against the direction of fuel flow, to lift anything off the internal screen) several times.
Any Porsche or MB place that works on CIS cars should have a CIS injector tester that lets you measure the crack pressure and observe the spray pattern. I junked two out of six - which, at $140 a pop for RoW 930 injectors, I thought was kind of a result....
'77 S with '78 930 power and a few other things.
Old 10-13-2012, 05:52 PM
Red Line Service
Marc Bixen's Avatar
Yes a Bosch CIS injector tester and some mineral spirits will fix a lot of injectors. We use our tester ALL the time. We still replace injectors but many times you can clean them. If your going to store them, put a little ATF through them before you put them on the shelf.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 10-14-2012, 08:53 PM
Laneco's Avatar
We usually send our CIS injectors to a local diesel repair shop - might check that option. For the newer 911's with the electronic injectors, we send those to Witchunter in Seattle.
angela
Hello
Old 10-15-2012, 05:04 AM
AutoBahned
RWebb's Avatar
yes, any Cummins shop can do it - Or. Fuel Inj. is the local go to place here
Old 10-15-2012, 10:53 AM
Walt Fricke's Avatar
Some day I'm going to use one of several spare brake master cylinders to make an injection tester. Mount with a lever, put in a pressure gauge, and find the fittings needed to screw onto the injector. Use any old container as a reservoir for the fluid.
some day.
Old 10-15-2012, 05:30 PM
Test opening pressure......
Check the opening pressure. I segregate or classify the CIS fuel injectors according to the value by which it starts to spray uniform mist pattern. Group I (35 - 39 psi.), group II (40 - 45 psi.), and group III (46 plus psi.). They should not drip at standby and produce uniform mist spray pattern to pass the test. Group I is classified as VERY GOOD, group II as GOOD or ACCEPTABLE, and group III as REJECT. While group III fuel injectors could still make the engine run, I avoid using them.
Tony
Old 10-15-2012, 06:21 PM
Free minder
Aurel's Avatar
I cleaned mine in an ultrasonic bath of IPA. They came out as new.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 10-15-2012, 09:34 PM
wachuko's Avatar
Thumbs up
Tony
Tony, I have a new set just standing by (that I was going to use in the RS project) in case I need to trash the ones in the car. Those were the pressure values that I needed. When I get back home I will remove them again and test with 35-39 psi.
Right now I think I have a fuel pump issue... but I did not have the time to check everything well before getting on a plane... I will spend Sunday troubleshooting the fuel system. Car used too run fine but the rust in the original tank took out two pumps before I figured out what it was... a new tank later... I need to go over the system again.
Drive safe!
1967 - Porsche 912
Old 10-16-2012, 05:10 AM
Bob Kontak's Avatar
Was it the beer or the ultrasonic that did it?
1981 911SC Targa
Old 10-20-2012, 10:01 AM
