Where to purchase fog lamp switch bulb?
Just purchased a great switch from Andrew15 (Thanks Andrew) to wire into the fan on a newly installed ER front cooler. The bulb that the switch calls for is a " Form W ". Anyone have any idea where to purchase this?
Thanks For The Help,
Dana
Specifications
On-off switch (NO)
No. 0340006012
Load max. 100 W / 24 V
Attachment with knurled nut M 12x1
Installation Ø 12,5 mm, wall thickness up to 6 mm
Connection Tab connectors or screw terminals
For rear fog light
Safety gear knob with black soft PVC and control lamp
Green lens mounted, red and yellow lens enclosed
12-V bulb installed
Bulb (Form W)
No. 1987302208 (12V 1.2W)
1987302504 (24V 1.2W)
Illustration
Circuit diagram
Old 10-26-2012, 04:48 PM
muck-raker
kidrock's Avatar
FLAPS or Radio Shack
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-26-2012, 04:57 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 flaps, it is a standard, readily available bulb
'85 Carrera Targa
PCA/POC
Old 10-26-2012, 05:04 PM
Duh. Should have thought of that. Just never heard of that size.
Thanks.
Old 10-26-2012, 05:10 PM
Formerly known as Syzygy
Canada Kev's Avatar
Just take the bulb out and take it with you down to your FLAPS. They should have them.
Kevin
Old 10-27-2012, 09:52 AM
