My other ride is a C-130J
Access to fog light switch
Hi gang,
I am installing a factory Fog light switch in the dash of my 1975 S. I was hoping I could have easily accessed the switch through the hole were the radio goes. Unfortunately you cannot gain access through that route. Do you access to fog light switch through the front of the car? Is the only way to access the fog light switch through the front of the car, by removing the front blower assembly and the associated piping. Thanks
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Member 911 Anonymous
Sorry to write: YES :-( Everthing basically needs to be pull out to get your hands in there to unscrew and disconnect the wires, mark them carefully before disconnecting.
Try to get While you are in there items done. Before putting everything make sure it functions properly and not interefere with other components. my system is hooked up to the central door lock, Ask me how I know :-(
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks.
I feared that
It's no big deal just time consuming. If you need any help PM me
