tpweiss9953's Avatar
Battery Drainage help!
So my battery drains after about 18 hours. I noticed when i opened my decklid that the part in the picture shown below seems to have a current going through it. Any ideas?
Not my engine shown.
Old 10-27-2012, 09:16 AM
If you measure the amps your car ia drawing at rest, you can pull fuses and relays one at a time to see which one cures the draw. Then zero in on components in that circuit.
Many times bad door switches stick and drain your batt. See if your power windows always work. They shouldn't after you've opened your door.
Old 10-27-2012, 09:57 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery Drain.
Good advice.
18hrs would indicate something is pulling about 3A.
Hope this helps:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-27-2012, 10:00 AM
[QUOTE=tpweiss9953;7055870]So my battery drains after about 18 hours. QUOTE]
Had the same problem a while back. Drove me crazy! Problem was the glove box light switch was turned on and that little bulb drained the battery over 18-24 hrs!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-27-2012, 10:06 AM
Hodgey's Avatar
Many times bad door switches stick and drain your batt. See if your power windows always work. They shouldn't after you've opened your door.[/QUOTE]
I don't get that.....mine continue to operate providing the ignition is on and my battery never drains.
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 10-27-2012, 10:08 AM
P/w.
Correct, they should not.
I don't get that.....mine continue to operate providing the ignition is on and my battery never drains.[/QUOTE]
1986 911 Targa.
Only in L.A.:
Old 10-27-2012, 11:32 AM
Part?
Originally Posted by tpweiss9953 View Post
The current is coming from the part in the pictured that i arrowed. What part is that? That is what is drawing from the battery.
Looks like the ICV?
Please provide a close-up pic.
Is this it?:
1986 911 Targa.
Only in L.A.:
Old 10-27-2012, 11:37 AM
Icv
Yes that is it.
This item should not be active with the key in the"Off" position.
In the "start or run" position, it will produce a slight vibration.
Pull the connector, and check your battery drain as per my other post.
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-27-2012, 01:26 PM
What is the ICV?
Idle Control Valve.
Do you have a Bentley manual?
1986 911 Targa.
Only in L.A.:
Old 12-06-2012, 06:58 AM
Just UNDO it!
turbolader's Avatar
Google says idle control valve.
Mike
Future ..: '69-73 911
Present : '97 Tacoma 4x4 Excab V6 White
Past .....: '65 356C White : sold
Two different 1970 VW beetles both forest green
One got totalled in head on. The other sold
Old 12-06-2012, 07:02 AM
Sounds like your ignition switch may be bad? Anything else seem to be powered up? Does the car start up and shut off correctly?
Chuck.H
'89 TurboLookTarga, 342k miles
Old 12-06-2012, 07:17 AM
Sometimes the car just doesnt shut off completely. Wants to continue running. Nothing else seems powered up.
You may have an intermittent ignition switch causing the ICV to go "active".
I'm not familiar with the current draw for the ICV.
Maybe, someone will chime in.
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-06-2012, 07:32 AM
Have you changed out the DME relay? This is a 'wear item' and easy to change. Maybe the computer is staying powered up after power is removed from the relay.
Chuck.H
Old 12-06-2012, 07:35 AM
You could stick a test light in pin 86 of the relay socket when it is out and see if there is power there. Also feel if it clicks when you remove it.
Rick
88 Cab
Old 12-06-2012, 12:16 PM
