scotricker's Avatar
How do I remove the Bumpy Undercoat on the front Valance?
I want it to be just smooth metal. I don't like the bumpy undercoat. I know it's all factory original and all, blah blah,,,etc... How can I remove that stuff? Scrape? Paint Remover?
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 10-27-2012, 02:19 PM
heat gun and a scraper. it will get all chipped up if it's smooth though.
206 637 4071
Old 10-27-2012, 02:41 PM
Formerly known as Syzygy
Canada Kev's Avatar
Yep, what JW said. Though if you use a heavy duty paint like Imron or Endura, it'll take longer to get all chipped.
Kevin
Old 10-27-2012, 03:12 PM
Certified User
billjam's Avatar
I have just been through this exercise and tried a few methods.
Sandblasting didn't even look at it.
A scraper clamped to heat gun worked reasonably well, but still left residue that had to be wire-buffed off.
During the wire buffing stage, I found that a good stiff wire buff on an angle grinder was by far the easiest way to remove the coating regardless of whether it was the residue from scraping or full thickness (about 2mm), so I ended up doing most of it with the angle grinder and wire wheel.
I removed the coating from the inside as well, so some small wire buffs (1/4" shank) in my electric drill got me into the tight spaces where the 100mm angle grinder wouldn't fit.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 10-29-2012, 07:17 AM
Mine came off easily with 'aircraft' paint remover. I did get the 3M stuff to recover it though, I think it's call shutz or something. Comes with it's own sprayer that attaches to the bottle. In my case I got lucky because the 3M white matches my GP white pretty good, so I just sprayed and clearcoated it.
I don't normally use paint remover, but this is a discreet piece that when off the car can be rinsed pretty good afterwards...
Chuck.H
'89 TurboLookTarga, 341k miles
Old 10-29-2012, 07:22 AM
Chain fence eating turbo
Someone here posted they used one of those multi-tools that has the vibrating head that barely moves left and right. Simply used the blade type one and it sawed right through the stuff fairly easy according to the OP.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-29-2012, 08:07 AM
Carmagic.us
rothaus's Avatar
Does the wire wheel not also remove the galvanized layer from the sheet metal ?
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 10-29-2012, 09:21 AM
kodioneill's Avatar
I think this is the best method. +1 worked good for me.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-29-2012, 09:45 AM
I would rather be driving
jpnovak's Avatar
You rang?
Undercoating Removal - The Fastest Method Yet!
follow this up with a wire wheel and you have nice clean shiny metal waiting for degrease and primer/paint steps.
Old 10-29-2012, 10:15 AM
scotricker's Avatar
thanks! I love HF. I'll go get one of those .
Scot
Old 10-29-2012, 11:07 AM
Originally Posted by jpnovak View Post
You rang?
Ha, I didn't realize that was you that posted that.
Old 10-29-2012, 11:19 AM
