French Import
![]() I started another thread for the work I am doing on suspensions/brakes, then I'll come back to this thread and update.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
French Import
Flywheel out (I used a spring plate as the "special" tool to lock the flywheel while removing the nine 12 point bolts
)![]() ![]() ![]() I took my flywheel to the local machine shop and the guy just freaked out once he recognized the Porsche part and said he could not do it. ![]() Anyone knows of a local shop that would do this?
French Import
Guess who?
You'll never guess who could resurface my flywheel...
Motor Meister - Porsche Engine Rebuilder Like it's going to happen!
83 911 Production Cab #10
Could not find a "Testimonial" link on their website ![]() ![]() ![]() Gilles Comment vas "the while your are in there"???
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
French Import
French Import
As part of my vert slowly moving project I am replacing the clutch cable, following this tech article Pelican Technical Article: Clutch Cable Replacement - 911 (1965-86) - 930 Turbo (1975-86).
I have released the cable at the clevis and now trying to pull from the engine side. The cable seems to resist my pulling and tugging and I am wondering if I just need to use more force or if I am missing a retaining clip... This is where I am at (pic from the tech article). ![]() Do I just grab the cable with pliers and pull harder? I prefer to ask the stupid question and not break something at the firewall. Thanks!
