your favorite degreaser?
i am using Gunk brand and it smells like crap ..
'69 911E Targa
'87 Carerra Coupe
Old 09-21-2010, 09:56 PM
You'd be better off using diesel.
Old 09-21-2010, 10:00 PM
Tsunamiboy's Avatar
Grease eater, it's supposed to be bio deg.
Spray brake cleaner, but don't spray it on anything that is supposed to be sealed (ball joints, CV's, etc.)
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 09-21-2010, 10:13 PM
AutoBahned
RWebb's Avatar
varsol
wurth has a good cleaner if that's where you're at
I would not use parts cleaner on greased parts. On cvs I use diesel, then super clean, then lots of hot water and dish soap. Finish with isopropyl or Brakleen.
Old 09-21-2010, 10:18 PM
Purple power sold at walmarts, and a few parts houses.....been using it for years....cheap and supposed to be eco freindly
Mike
Valley Grande, AL
1987 911 Targa, White
Old 09-21-2010, 10:25 PM
Simple Green.
Old 09-22-2010, 01:16 AM
tobluforu's Avatar
Castrol makes a product that you can find at ace or parts stores, and that stuff eats through all grease that I throw at it.
CASTROL SUPER CLEAN CLEANER DEGREASER 101780 SUPER CLEAN BRANDS INC.
Old 09-22-2010, 04:19 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Seventh Generation Cleaner...
As they say; The proof is in the pudding (photos) http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
Who Will Live... Will See
Old 09-22-2010, 05:09 AM
simple geen (dont use on tires though)
Old 09-22-2010, 05:11 AM
Super clean is good stuff. It does an amazing job. Just don't leave it on very long or it will eat aluminum.
Old 09-22-2010, 05:14 AM
Bill Verburg's Avatar
Simple Green also eats aluminum if it's left on too long, the nice thing about diesel and kerosene for cleaning is that they leave a protective coat, of course if you want clean metal that isn't so good
Bill Verburg
Old 09-22-2010, 06:14 AM
Shaun @ Tru6's Avatar
my parts washer has a 50/50 mix of diesel and purple degreaser. works well for everything but Mg. Al is fine in it.
I like the film at Bill says, but a quick spray of brake cleaner yields a perfectly clean part.
Tru6 Restoration & Design
Old 09-22-2010, 06:45 AM
Yup.
If you use Super Clean or Purple Power, wear gloves and it's best to use it diluted or spray onto parts that are cool and already sprayed with water beforehand. Don't let it dry, and never spray onto plastc or rubber.
I like diesel because it cleans off easily. I feel that Simple Green leaves too much residue. You can smell it on your engine despite several rinse steps.
Old 09-22-2010, 08:05 AM
shbop's Avatar
Originally Posted by rusnak View Post
you'd be better off using diesel.
+1
Jon
Old 09-22-2010, 08:41 AM
Awesome! Thanks for all the great input. I'm using the cleaner it to detail my '69E engine while it's out. Going to repaint all the panels and clean off the MFI unit and lines, green shroud cover, underside of the case, etc. Only has 53k miles on it so don't want to crack it open. I'm going to add collars to the oil feed tentioners though.
'69 911E Targa
'87 Carerra Coupe
Old 09-22-2010, 10:37 AM
esotoracing's Avatar
Formula 88 for many many years. works on anything and is bio
theres nothing like the rear end squatdown of a turbo
Old 09-22-2010, 10:44 AM
bart1's Avatar
Xenit!!
Old 09-22-2010, 12:20 PM
AutoBahned
RWebb's Avatar
use wood scrapers first
then a non-polar solvent
then a polar solvent (detergent)
Catrol purple seems MORE aggressive than Simple Green & will remove paint
after, coat any Mg surfaces with Tectyl or something
Old 09-22-2010, 12:25 PM
What is the detriment to using Simple Green on tires? What would you use instead?
Dave
'75 911s Coupe
