LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
78-911SC's Avatar
Chris I think it might be the website. I'm noticing it on other pelican posts. They must be having issues. Normally use safari but also tried foxfire with no luck. Thanks
PJ
78 911sc Targa
70 911T
Old 04-02-2016, 03:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
3 restos WIP = psycho
kenikh's Avatar
For now, use photobucket
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-03-2016, 12:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Porsche Nut
merbesfield's Avatar
Same here, web site not showing pics.
Old 04-03-2016, 01:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
cnielsen's Avatar
Pic are working so here are the photos showing the intake manifold and EFI fuel rails
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 04-03-2016, 08:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
cnielsen's Avatar
From here we could start playing with intercooler options and where we could put it so it would fit under the stock decklid. Eliminating all the CIS components created a lot more room.
Then Levon had the brilliant idea to mount fans on top of the intercoolers since we won't have forced air from a close fitting rear spoiler.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-03-2016, 08:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
cnielsen's Avatar
At this point we were running Electromotive and we were about ready to run the motor in on the dyno. Things fired right up and Levon set forth programming the EFI. Within the early stages of tuning, the air fuel mixture went haywire and kaboom! Levon cought things as quick as possible but the damage was done. The result was two melted pistons and cylinders. We were armed with a mountain of data that pointed towards the electromotive system. Levon spent a lot of time sorting all this out....long story short, he rebuilt the motor and we ditched the electromotive in favor of Motec and from there on out it was smooth sailing!
I'm not here to point fingers at a particular product but what I can say is during the final tuning process, it became apparent that Motec was a far superior system with much greater tunability.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-03-2016, 08:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
@_more_momo
Outlaw_singer's Avatar
Originally Posted by cnielsen View Post
Wow, that is just pure... porscheporn!
Old 04-04-2016, 12:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Chain fence eating turbo
Oh wow, your thread needs to be in the 930 forum too if you're going to post under lid IC porn!!
Old 04-04-2016, 03:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
911 tweaks's Avatar
very nice build chris... like ALL of the work you do... can you share some specs of the engine internals for some of us that are now dreaming of making such a motor...ie:
what are the motor bottom end specs ie 3.2 or 3.3L or...?
what engine compression are you running...?
do you have a pic of the piston tops which I presume are flat...?
how much turbo boost pressure did you have to run to get 590+ hp...?
I would guess that in addition to the great work you and levon did creating this motor, that the "tweak" to the motec is the special sauce to make this all happen & to keep it alive for a long life... any general ball park costs to make such a complete motor pkg from intake, turbo, motor, exhaust, motec work, ect...? I would guess north of 25k...? thx for sharing what you can...bob
I live for 911 tweaks...
Old 04-04-2016, 05:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
cnielsen's Avatar
If anyone wants to build a turbo motor and debating on your management system, just look at this pic and then go spend a little more money and buy Motec.
Levon took the motor completely down to the crank so everything could be checked. And then the rebuild process started again. You'll notice some new bits going on, including a twin plug distributor and an RSR crank pulley.
Then unpacking the Motec goodies and Levon took extra care to fabricate a beautiful plug and play wiring harness.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 05:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
911 tweaks's Avatar
WOW chris... just WOW WOW WOW... I now raise my est way north of 25k... man would i luv a motor like this...
Old 04-04-2016, 05:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
cnielsen's Avatar
Thanks Bob,
As I mentioned before, the motor started life as a 1991 3.3L 965 turbo.
P&C's are Mahle Motorsport 3.4L and you can see the piston shape in the photo above.
Boost was set at around 0.8 bar.
There were a lot of internal mods in the valve train, cams etc...but that is Levon's "secret sauce".
The motor was designed to be very reliable and streetable. I was not on a quest for big HP numbers, but it was a pleasant surprise in the end!
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 05:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
Deleted original post as the facts are in
Old 04-04-2016, 06:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
wow! that escalated quickly!
Old 04-04-2016, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
cnielsen's Avatar
Like I said, my intention is not to bash a company but it is hard to restrain knowing how much time and money this cost us AND the mountain of data that accompanied the event. The timing and A/F were all overly conservative. I won't go into details because they are above my pay grade but even Electromotive said everything pointed towards their product.
BTW, I've run Electromotive on other normally aspirated cars with zero problems. I just wouldn't run it on a turbocharged motor.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 06:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
That's good to know EM owned up. Must have been a MAP or injector driver issue.
Old 04-04-2016, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
cnielsen's Avatar
Well they only partially "owned up". Meaning they agreed that it looked highly suspicious and they replaced the ECU etc but we weren't going to chance it after that. We were on the hook for the mechanical repairs.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 08:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
cnielsen's Avatar
Back to the intercooler...
Levon called me one morning and said he woke up in the middle of the night with an idea to maximize the efficiency of he fans. He theory was that a decent percentage of the air moved by the fans was bypassing the intercooler by being blown back out the corners. So his solution was to build block off plates on any area not covered by the fans.
The end result was a significant drop in temps. Final dyno runs showed inlet temps at 270 degrees and outlet dropping to 105...that 165 degree drop!
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 06:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
cnielsen's Avatar
And then finally we are back to a fully assembled motor and back on the dyno for final tuning.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 04-04-2016, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
Love the data. What were ambient temps?
Old 04-04-2016, 06:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
