water on the floor I need help
I need help solving a few issues...
I picked up a 76 911 from my brother..I live Vancouver Canada..Ya it Rains. Anyways I'm getting water coming in from so many places its crazy.. First thing I did is replaced the seals and re installed the windows front and rear. I think it helped..But today I woke up to ! inch on the passenger floor.. I took of the door panels and they are soaked.. I put a hose against the window and water was running in through the speaker. Anyways I'm having a brake down..!! The car is sweet and mechanically great.. But I cant put in the new carpets till I solve all of the issues.. I think i should take the doors of and seal the openings to see if the windows have been done right or is it a door seal... Question....??? are the doors inside supposed to be dry? I mean they do have drain holes and no door is crazy water proof?? Has anyone had any issues like this ? any suggestions? ![]() ![]()
Sunroof drains?
If you have a compressor gently blow out the sunroof drains. Over time they get clogged with all sorts of things...
'77 Porsche 911S |
Caveman Hammer Mechanic
"I put a hose against the window and water was running in through the speaker."
Pull the door cards, the plastic water barrier is most likely damaged or missing.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
+1 on plastic water barrier being missing...
Also make sure drains in your door bottoms are clear. Some water will naturally run down the window glass and through the door shell. |
A weatherproof fitted cover wouldn't be a bad idea
Even after this issue is sorted out. |
Member 911 Anonymous
Check the windshield wipers and the washer nozzle for looseness, if so that is where the water is coming in from. I bet when you drive in the rain it leaks onto your foot, right?
Ask me how I know???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
