Booney1golf's Avatar
Still missing after DME relay, plugs, wires, Dist. cap & Rotor?
I have an 87 911 3.2 that was running fine then I went about 3 months without driving it more than just starting it in the garage every 2 weeks or so.
I started it and it was missing some so I decided to change the wires, plugs, dist. cap and rotor & DME relay since I was not sure how long it had been. The car may run better but still has a slight miss when at idle or even when driving normally. The car seem to pull strong when I get on it but several people have heard the car and seem to think its a fire and not a fuel issue. The Fuel filter was also changed recently.
I thought about changing the coil but I hate to keep guessing due to all of the sensors, etc..
I'm trying to avoid just taking it to a shop but I might have to unless someone has something relatively inexpensive I can try.
Thanks for your time in reading my post!
Daniel Womack
1987 Porsche 911 Cab Wide-body
1998 BMW M Roadster
I love speed!!!
Old 11-29-2012, 02:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the ohms on the ref/speed sensors.
'85 Carrera Targa
PCA/POC
Old 11-29-2012, 06:19 PM
sounds like you have a non firing injector. They get that way from sitting, even a short time. Tap it, they will come alive.
Bruce
Old 11-29-2012, 06:31 PM
kodioneill's Avatar
Possible that you may have a vacuum leak. Sometimes the brake booster hose get's brittle and cracks on the back of the engine. Acquire a vacuum gauge and check manifold vacuum at idle should be near 18 hg.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-30-2012, 05:22 AM
Bruce
To test this theory you can feel or listen (with a stethascope) to each injector - they make quite the clicking when they are functional.
Another test you can do is to get an infrared thermometer and look at each exhuast port to check temperatures - a non firing cylinder will be colder than the others... this is a good way to isolate bad injectors, spark plugs or plug wires.
Chuck.H
'89 TurboLookTarga, 342k miles
Old 11-30-2012, 05:59 AM
T77911S's Avatar
drive it and then pull the plugs. also check for air leaks. check the intake bolts. injector Orings too. you may just have a smoke test done,
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-30-2012, 07:15 AM
Thanks to each of you. Some of these things I can do others are out of my knowledge scope. I will go forward with what I can and report back.
I appreciate the time spent reading and responding to my post!.
Daniel Womack
1998 BMW M Roadster
I love speed!!!
Old 11-30-2012, 08:06 AM
Bandwidth AbUser
Jim Richards's Avatar
How old is the gas?
How's the O2 sensor?
Jim R.
Old 11-30-2012, 08:36 AM
Diss Member
Quicksilver's Avatar
Sent a PM
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-30-2012, 09:55 AM
Thanks again for all of the help / responses. I put 1/2 tank of Super unleaded then added 12 onces of Lucas gas treatment and drove the heck out of the car once it warmed up.
The feeling of driving a Porsche that is running as it should: Priceless!!!
Thanks again to each of you through the years that have helped an average non mechanic be able to drive and own 4 different 911's!!!
Daniel Womack (Booney1golf)
1998 BMW M Roadster
I love speed!!!
Old 12-07-2012, 07:51 AM
