Wew Wew is online now
SC Mutt
Wew's Avatar
Give me a brake
Evening. Working away on 911 sc 1978 targa. Car does not want to roll forward or backward. In neutral with e brake off. Finally got to solid animals to help me push the forward. It was stuck good. Car did sit outside for 3 years and was never started or moved. I am addressing the engine stuff.
Now for the kicker. I try to roll the car backward a week later and of course it doesn't want to budge. I get in drivers seat and go to push in brake pedal and it won't budge. I mean this sucker won't move no matter how hard I press down on it.
So, I am here asking for advice and help. What should I do?
All input is much appreciated.
Gary
Old 12-10-2012, 10:05 PM
twistoffat's Avatar
Sounds like the brake booster needs replacing
Old 12-10-2012, 10:09 PM
Senior Advisor
James Brown's Avatar
time to rebuild all 4 calipers and look at the master cylinder. Rust from moisture surly has rusted them firm. Start with the rears, you can also check out the parking brake. the kits and pads are inexpensive.
08 Cayenne Turbo
Old 12-10-2012, 10:23 PM
RETIRED
Joe Bob's Avatar
The booster works when the engine is running. I would start trouble shooting. Got fluid? Crack the bleeders and see what comes out.....check the brake hoses. Could be internally swollen and blocked. Frozen master cylinder, bad bushings in the pedal cluster.....
Rubber lines and fluid are cheap and are replaceable maintenance items....
2012 ML350 3.0 Turbo Diesel
Senior Advisor
so far we got, hoses, fluid, rebuild kits, pads. All relatively cheap,.... so far
08 Cayenne Turbo
Old 12-10-2012, 10:26 PM
SC Mutt
Wew's Avatar
Yikes. O.k. Sounds like the hoses and fluid make sense, and may as well rebuild the calipers. I am sure there are some really good write ups on that. How would I know if the master Cylinder is bad?
On the bottom of the dish there is a rust pattern like something leaked out of it. I will take a picture next time to send.. It sounds to me like everyone is saying one step at a time and potentially go through the entire system.
What would be the correct order?
Thanks again for all the great advice and input.
Gary
Old 12-11-2012, 10:58 AM
RETIRED
Joe Bob's Avatar
Have someone pump the brake pedal while you watch the action of the calipers and brake pads.
If the pads move and clamp down on the disc the MC is working. If not then fluid is not being compressed by the cylinder either because there is no fluid or the MC is defective or there is a blockage in the lines.
Got to be one or combination of the above.....
Old 12-11-2012, 11:04 AM
SC Mutt
Wew's Avatar
O.K. Will do. The problem is the darn brake pedal won't move. I mean literally I can't pump it. it is like stuck all the way open. I cannot depress that sucker one fraction of an inch.
Old 12-11-2012, 01:47 PM
RETIRED
Joe Bob's Avatar
Pull the carpet up remove the pedal board and get your head down there with a good light. The pedal cluster may be frozen up with crud and rust.
A PB Blaster soak and a couple of taps with a rubber mallet may do a world of wonder.
Old 12-11-2012, 02:09 PM
SC Mutt
Wew's Avatar
Awesome. Thanks. Gary
Old 12-11-2012, 02:20 PM
non-whiner
mreid's Avatar
Does the parking brake work? Was it left on all that time? You may have at least two problems...
"Too much is just enough."
Old 12-11-2012, 02:26 PM
Hi Gary had the same thing happen to me just after I purchased my 73t it had sat for
About 12 years in the po's garage and three days after I got it home it froze to the floor.
I rebuilt the calibers replaced the master Cylinder as it was leaking through the bellows
Into the pedal cluster area and rebuilt the cluster which I believe was the real problem
For the frozen issue. Also changed fluid and changed rubber bake lines.
Hope this helps
Mike
Old 12-11-2012, 05:04 PM
SC Mutt
Wew's Avatar
Absolutely. It all helps. And that makes sense. Because it sat outside for 3 years in sf and yes the parking break was on when I bought the car so I can only assume it was engaged the whole time.
Old 12-11-2012, 09:46 PM
