NotaFastM's Avatar
3.0L to 3.2L engine conversion(swap). Help!
Hello all,
I have decided to swap out my toast 3.0L engine for a 85 3.2 engine. I have been doing a lot of reading. I am wondering if someone has direct instructions on the whole swap. I have searched on this and other sites, very hit and miss on direction.
Any help would be great. I have wiring diagrams at present but somewhat concerned about fuel pump/lines as I am not finding much info on the setup.
Thanks so much in advance!
Old 12-07-2012, 04:41 PM
Fuel line sizes are somewhat critical, as too big or too small can affect the ability of the pressure regulator to function. It might be handy to find somebody in your area with a 3.2 that you could take notes from.
Does your 3.0 have a fuel return line? Sorry I'm only familiar with the 3.2's...
Chuck.H
'89 TurboLookTarga, 343k miles
Old 12-10-2012, 05:14 AM
BoxsterGT's Avatar
Porsche Crest
I can help you with new replacement fuel lines & the latest in multi-fuel hoses. Shaun 84 Targa and others can help with wiring info and other issues. He has done the swap himself; is very knowledgable on this and knows where to source the parts.
Actually, lots of info available from the entire Pelican community. A 3.2 upgrade to an earlier model is a very popular swap.
Len
Old 12-10-2012, 05:28 AM
Laneco's Avatar
You can re-use your 3.0 fuel pump. Have Len make your hoses for you - then the fuel system is handled. His work is great. The 3.0 has a return line and you will be reusing it with a custom hose.
My car is an 81 SC with an 85 3.2 in it. I reused the 3.0 pump because it was BRAND NEW and had Len build my lines at the rear.
angela
Hello
Old 12-10-2012, 06:26 AM
redstrosekNic's Avatar
Sorry I can't provide information with the swap, but I just wanted to extent a warm (or rather cold and rainy) welcome to Pelican from a fellow NE Ohio guy. Are you a member of the PCA? I am currently working on setting up a local (Strongsville area) cars & coffee schedule for PCA for the Spring and Summer of 2013. I'll shoot you a PM if you want, containing more specific info when I figure stuff out.
Good luck with the swap!
Dustin
Old 12-10-2012, 06:36 AM
I would rather be driving
jpnovak's Avatar
This should help answer all your questions.
Index for Marc's 2.7 to 3.2 Conversion
Old 12-10-2012, 07:09 AM
Chain fence eating turbo
That is a great writeup.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-10-2012, 07:40 AM
+1! This will definitely help me in the future, as this swap looks attractive
Dustin
Old 12-10-2012, 08:16 AM
NotaFastM's Avatar
Thanks so much for the help! I am planning on picking up the engine, harness, DME etc this weekend. Let the fun begin after that.
I am a little concerned about the 915 to 3.2 fit but will see.
pic's to come!
Old 12-10-2012, 03:16 PM
jpnovak's Avatar
AS long as you have the 3.2 915 flywheel it will bolt right up. The only difference is that you hve to make the notch for the reference and speed sensors in the top of the transmission bell housing. Your 911SC based 915 casting does not have this sensor notch opening.
Just don't forget to align the clutch fork when you slide them together.
Old 12-10-2012, 03:27 PM
bennysc1
Hello:
I am new to Pelican. I live in Concord Twp, Ohio which is a North East of Cleveland. I would be ingested in reading more about this post regarding the engine swap. Good luck with your project. I do have some Porsche manuals to review if you like.
Old 12-10-2012, 06:20 PM
bennysc1
Sorry but I forgot to mention that I have a 83 SC
Old 12-10-2012, 06:21 PM
Senior Advisor
James Brown's Avatar
Oh and don't forget to put the starter ring on the pressure plate, many think (or forget to think) that the tone ring is the starter gear, there should be 2 rings back there. Several have done this
08 Cayenne Turbo
Old 12-10-2012, 08:19 PM
NotaFastM's Avatar
Thanks again for the input! I am off to NC this weekend to pick up the engine and assorted pieces to make this work.
Will be posting photos of work proceeding.
Old 12-11-2012, 04:32 PM
Laneco's Avatar
We did too... The good news it's that when it happens, you get to practice taking your engine back out with your wife's help. Your wife will be pissed and give you mean, hostile looks the whole time.
angela (the wife)
Hello
Old 12-11-2012, 06:46 PM
engine swap
Wow! This info is great!
I have a 1980 SC in which I plan to install a 3.5 engine
Old 12-11-2012, 09:30 PM
